teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
15-02-2008, 22:25 Subject: Polo 71: 75 HP Version |
Hello, I'm shopping online again.
My old 1.4 TDI had 75 horsepower, the 2005 model had 71! (There are also versions with 80 horsepower.)
"Does anyone know the difference in driving characteristics?"
Did they reduce the power to 71 horsepower in favor of quicker acceleration?
My old (non-VTG) camera came with a 1-minute timer that was barely usable. Has that improved?
It seems that only the A2 model with the 90 horsepower engine comes with VTG (Variable Turbine Geometry).
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 19-09-2026, 23:35.
Profile PM Email Garage |
16-02-2008, 17:52 Subject: Polo 71: 75 HP Version |
Breaking news: I bought a Polo. Engine code: BNM. It pulls well from 1500 RPM, and it runs for 1 minute.
The Fehlespeiche is free.
Leider kann ich die MWB nicht logen, weil die Bereichsgruppen sich nicht auslesen lassen! ZB: 01 Motorsteuergerät wird nicht erkannt- fehlt mir da was (Labeldatei) in VAG Com? Version 704.1
Note: Unlocks hexc 715-00a8d1-b1f5d-24f1f3 olicil-6198.
Translated on 19-09-2026, 23:36.
vagtuning Guest
16-02-2008, 18:11 Subject: Polo 71: 75 HP Version |
'In the addendum, a digit is missing.'
Generally speaking, it should work, but I haven't had any experience with it on a BlueMotion Polo.
probs.
Translated on 19-09-2026, 23:37.
16-02-2008, 18:37 Subject: Polo 71: 75 HP Version |
Thanks. I can rely on you for things like this.
Is this the MSG? Version 09. Part number 6Q1937049D, code 09246, component 00AF BN-SG 1S34.
All areas are shown as not occupied, with the exception of area 02: Voltage 14... Volts, and doors are open/closed.
But I think we're moving on to a different topic now! (Maybe we should move this discussion.)
Translated on 19-09-2026, 23:38.
vagtuning Guest
16-02-2008, 18:39 Subject: Polo 71: 75 HP Version |
No, 09 is the body control module (BCM)  .
01 is the engine  .
It might be a part number like 045 906 019 BP or something similar.
Translated on 19-09-2026, 23:39.
16-02-2008, 18:47 Subject: Polo 71: 75 HP Version |
You might find it amusing: logically 09 BN STG - voltage and doors.
Don't come to 01, but I want to see  .
So, that has nothing to do with the label files, right?  I have no idea.
What should I do? I've already looked for updates, and VCDS (Vag Com) is up to date.
Translated on 19-09-2026, 23:40.
vagtuning Guest
16-02-2008, 18:55 Subject: Polo 71: 75 HP Version |
'Even if there are no labels at all, you can still find the main cable (stg) yourself.'
Inside, you will only find the terms listed below the advertisement.
At an existing/non-existent connection between VC and...
They have absolutely nothing to do with the control unit.
Why don't you download the English 711 beta?
http://www.ross-tech.com/vag-com/download/beta/current.html
Although it's English, practice makes perfect  .
Translated on 19-09-2026, 23:41.
17-02-2008, 15:30 Subject: Polo 71: 75 HP Version |
vagtuning wrote: | If you're clean, you'll also come.
Although it's English, practice makes perfect  | .
Finally moved it from the internal drive to the external hard drive, then to the laptop, and now it's also in English. - jess - reddy - closed - ugh.
Does anyone want to see my super air mass? I have too much! LL leak? Hardly have I gotten in, and I already hear the fleas coughing  , but it's fun, thanks.
PS: I don't want to work with multiple versions  .
Translated on 19-09-2026, 23:42.
vagtuning Guest
17-02-2008, 15:56 Subject: Polo 71: 75 HP Version |
Does the 711 work?
Translated on 19-09-2026, 23:43.
17-02-2008, 16:36 Subject: Polo 71: 75 HP Version |
Yes, see the attached file.
vagtuning Guest
17-02-2008, 16:39 Subject: Polo 71: 75 HP Version |
I'm sorry, but I can't translate text without the actual text. Please provide the text you want me to translate.
17-02-2008, 17:08 Subject: Polo 71: 75 HP Version |
but now - sorry - (I had to switch to English)
Translated on 19-09-2026, 23:44.
vagtuning Guest
17-02-2008, 17:23 Subject: Polo 71: 75 HP Version |
I think the result is perfectly fine.
It's always fascinating how well the LD (likely referring to a specific system or process) is regulated in [context].
The small BMN and also the BMS (BlueMotion) are working  .
17-02-2008, 17:29 Subject: Polo 71: 75 HP Version |
Yes, that aligns with my own experiences!
The question relates to LMM (likely referring to a mass airflow sensor). If the sensor consistently shows a value that is "too high," is this normal to account for aging, and can the returned exhaust mass value be reduced without requiring a vehicle inspection or modification?
Translated on 19-09-2026, 23:45.
