I had been experiencing this for some time (the weather was bad, and the discomfort was minimal
Intermittent power steering failures during maneuvering.
This weekend, it was time for another oil change, and wouldn't you know it - the serpentine belt was also due for replacement.
The belt that drives the pump was very loose (the pump could be turned by hand).
Serpentine belt tensioned, operational / maneuvering - no more power steering failures...
but since last night, I've been hearing a 'rattling' (rrrrrrrrrr - sounds like a loose disc on a
(Wave that is not rotating correctly) has been noticed. The noise is speed-dependent.
and reaches a value in the range of 2000 to 2200 rpm.
Two things came to mind spontaneously.
a) The pump's bearing has been damaged due to the loose belt.
b) The belt itself vibrates or flutters at a certain rotational speed.
b) would, of course, be more pleasant (principle of hope
Has anyone else observed similar behavior or noises?
Rudi
