VW Golf 3 PD: Specs, Problems, & More
Golfmann
Post03-08-2002, 19:11    Subject: VW Golf 3 PD: Specs, Problems, & More Quote
Hi everyone!
I need some advice! I have a 90 hp 1Z engine, and it's now seized. The question is:
1. An AFN engine from an A4 (installed longitudinally) can fit in, with the exception of the transmission.
2. How difficult is it to swap in a 130 hp PD engine from a Golf 4 (including all the necessary components)? Would my 1Z transmission be compatible with both engines?
I would prefer the common rail diesel engine.
I would be grateful for any advice.
The Golfman.
Translated on 02-09-2026, 0:14.
yomam
Post03-08-2002, 20:24    Subject: Renovation: Complete Home Transformation Quote
Hello!
While I can't offer any technical advice regarding the renovation, I still want to share my thoughts.
A friend replaced the 1Z TDI engine in a Golf 3 with a PD-TDI engine. I drove it myself last week - the conversion was really done perfectly (I could take a look under the hood).
The engine is also running perfectly - no jerking/hesitation, no fluctuations in acceleration, etc.
Now, regarding the modifications (what he told me):
You will need:
- Electronic throttle from a Golf 4.
- Tachometer unit for a vehicle with 4 cylinders.
- Ignition switch from the 4-series.
- Wiring harness from the 4-series.
Bitte gib mir den Text, den du übersetzt haben möchtest.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
He had a diploma in electrical engineering (he's supposed to be an expert in this area). Apparently, nothing will work without the electronic components (wiring harness, etc.) from a fourth-generation Golf, specifically the electronic throttle, ignition switch, and speedometer – likely due to the immobilizer system.
The turbocharger is from a Passat. All the pipes and hoses are arranged across the Volkswagen shelf. The fuel cooler (if I remember correctly) is from a BMW 5 series.
He told me that absolutely nothing fits properly and that everything has to be somehow cobbled together.
The transmission is still the original 1Z model - so far, it's still working. During the test drive, no problems were noticeable.
There are certainly other people here who can tell you much more and who are capable of going into more detail.
Best regards, D.
Translated on 02-09-2026, 0:17.
Golfmann
Post04-08-2002, 13:12    Subject: VW Golf 3 PD: Specs, Problems, & More Quote
Okay, great, then the effort involved is way too high!
It would probably be more worthwhile to install an AFN (air fuel nitrogen) system and modify it with a chip.
Does anyone know if the AFN engine from the Audi A4 will fit in a VW Golf 3 1Z, or what modifications would be necessary?
Translated on 02-09-2026, 0:20.
TDIFan
Post04-08-2002, 18:53    Subject: VW Golf 3 PD: Specs, Problems, & More Quote
While I can't directly help you, here are two helpful links:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=1754525837
-> A TDI AFN transmission is available at a (still) great price. By the way, I'm not the seller and I don't know them. I just stumbled upon the auction by chance.
And for the renovation:
http://www.meckisfaq.de/antworten/motor/diesel/1z_2_afn.htm
According to the article, it's not a simple action. Especially the immobilizer is supposed to cause problems. But then there are the Russian friends icon_wink.gif.
Phil.
Translated on 02-09-2026, 0:21.
Varianti
Post12-08-2002, 15:16    Subject: VW Golf 3 PD: Specs, Problems, & More Quote
Hot tip:
Take the engine control unit (ECU) from a T4 TDI. icon_razz.gif It doesn't have an immobilizer.
Translated on 02-09-2026, 0:22.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Brake caliper-wheel bearing holder, Golf 2 GTD and Golf 1... Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
