kixx_ass Blaumann
Joined: 03/02/2005 Posts: 75 Karma: +4 / -0 Location: Stuttgart
29-03-2005, 19:58 Subject: Dashboard Malfunction: Troubleshooting Guide |
Hello everyone!
My G4 ALH has been experiencing intermittent issues with the instrument cluster for some time. The problem manifests as a temporary drop in the displayed RPM and speed, which then recovers.
Are these just minor fluctuations in the delivery unit, or is something bigger brewing?
Thank you for your help.
Audi S2 QP
Sokda Superb 3T
Translated on 29-09-2026, 0:51.
Günther Guest
29-03-2005, 20:18 Subject: Dashboard Malfunction: Troubleshooting Guide |
Sometimes my speedometer would stop working intermittently, and then it would fail completely; it turned out to be the speed sensor in the transmission.
If the speedometer and tachometer are affected, it's likely a problem with the instrument cluster.
Power supply? Connector? Does the rest of the device work?
Günther.
Translated on 29-09-2026, 0:52.
golf3schrauber Blaumann
Joined: 10/15/2003 Posts: 140 Karma: +1 / -0 Location: Erkelenz
29-03-2005, 20:54 Subject: Dashboard Malfunction: Troubleshooting Guide |
I'd also be interested in that.
I've been using an AI (artificial intelligence) system from a Golf 4 in my Golf 3 for almost a year.
I have encountered this problem several times in the past.
Just a moment ago, on the highway.
For a fraction of a second, the tachometer and speedometer readings drop.
I always blamed it on my modifications. But it seems like it's happening to other cars too!
It seems the AI systems are having some trouble.
Gruss Oliver.
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 29-09-2026, 0:53.
MichaC. Blaumann
Joined: 02/25/2005 Posts: 29 Karma: +9 / -0 Location: Wiesbaden
29-03-2005, 22:05 Subject: Dashboard Malfunction: Troubleshooting Guide |
This is a well-known problem!
I've already replaced several ECUs (Engine Control Units) with this type of error on the Golf 4.
"Micha"
Seat Toledo (1L) Bj.98 AFN 0.216er Düsen, VNT-17 Lader, 1,2bar Ladedruck, Speedbuster-Box, langer 5.Gang -- bis 03.06
VW Bora Variant Sport Edition Bj.02 AJM mit ******** OBD Tuning -- ab 03.06
Translated on 29-09-2026, 0:54.
Günther Guest
29-03-2005, 22:10 Subject: Dashboard Malfunction: Troubleshooting Guide |
Micha.
and what is the cause?
Günther.
Translated on 29-09-2026, 0:55.
kixx_ass Blaumann
30-03-2005, 7:31 Subject: Dashboard Malfunction: Troubleshooting Guide |
@günther: The rest of the AI is working perfectly! BC and Co. aren't messing around.
As long as it's "just" the givers, it's not that bad... but it's annoying.
Audi S2 QP
Sokda Superb 3T
chli1976 Profi-Schrauber
30-03-2005, 8:41 Subject: Dashboard Malfunction: Troubleshooting Guide |
I had the same issue with my Golf 4 AJM.
My speedometer, tachometer, temperature gauge, and fuel gauge have all stopped working.
I had to replace the instrument cluster because I couldn't find any replacement parts anywhere.
My analog-to-digital converter may have malfunctioned intermittently.
Try checking if the indicators work during the actuator diagnosis. If they still don't work there, then the control unit (KI) is likely defective.
Translated on 29-09-2026, 0:56.
kixx_ass Blaumann
30-03-2005, 16:30 Subject: Dashboard Malfunction: Troubleshooting Guide |
Thanks for your help, everyone!
That's helpful for now!
Best regards, Jan.
Audi S2 QP
Sokda Superb 3T
Translated on 29-09-2026, 0:57.
