Maik Guest
30-03-2005, 11:02 Subject: TDI Signal Consumption Measurement 1Z |
Does anyone know what kind of signal is sent from the engine control unit (ECU) to the instrument cluster (IC) to provide the fuel consumption data? Specifically, is it a simple DC signal, a PWM signal, or something frequency-dependent? And what is the magnitude of the signal, e.g., in volts per liter (V/L) or Hertz per liter (Hz/L) or something else?
Hopefully someone knows this, because my TDI doesn't have an MFA, and I'd like to build something myself.
Thank you and best regards.
Maik.
Translated on 14-10-2026, 7:29.
30-03-2005, 12:48 Subject: TDI Signal Consumption Measurement 1Z |
Hm, why don't you connect an oscilloscope to it and mess around with the gas  ?
You can convert a DA (digital-to-analog) signal using an analog voltmeter and attaching a new scale to it.
"Let me see it when it's done. I don't have an MFA either, just a daily mileage counter."
If it doesn't reach 1200, it means it's using a lot of fuel, because for some reason, my tank holds 70 liters.
Translated on 14-10-2026, 7:31.
Profile PM Garage |
Maik Guest
30-03-2005, 13:30 Subject: TDI Signal Consumption Measurement 1Z |
It was too stressful for me to run to the street with the oscilloscope, pull extension cords through the hallway, and then take out the AI unit. I thought someone here would know. There are always so many smart people around here  .
'Don't worry, it'll get better. I've already installed an LCD screen and a controller to display things like maximum speed, travel time, average speed, outside/inside temperature, and oil temperature. I also wanted to display the maximum and average fuel consumption.'
Translated on 14-10-2026, 7:32.
wutz Blaumann
Joined: 08/13/2004 Posts: 247 Karma: +11 / -1 Location: BRA 2006 Seat Leon Free account, no CAN development support
30-03-2005, 13:45 Subject: TDI Signal Consumption Measurement 1Z |
"How did you do that with the controller? I'm also in the process of building a kind of multi-function display. However, I'm not familiar with the controllers for LCD displays. I mainly want to display things like boost pressure, voltage, etc. I would be very grateful for any tips."
Michael.
Translated on 14-10-2026, 7:33.
Profile PM Garage |
Maik Guest
30-03-2005, 14:02 Subject: TDI Signal Consumption Measurement 1Z |
'Hello, I've been using a Siemens 80C537 microcontroller and a small 2x8 LCD display since 1996. I now have some free time and want to switch to a Microchip PIC microcontroller, rewrite the program, and add new features while removing features that are no longer needed. The programming is done in assembly language.'
What exactly are you planning to do, and how do you intend to solve it?
wutz Blaumann
30-03-2005, 15:30 Subject: TDI Signal Consumption Measurement 1Z |
I was thinking of using a 4-line (or possibly more) or a dot-matrix display to show multiple data points simultaneously, without having to switch between them. Since my car already has a MFA (Multi-Function Display), I wanted to display different information, such as voltage, oil temperature, boost pressure, etc. The display would be mounted in the headliner, near the light (which is at a nice angle in the Golf 4). That's my idea so far, but I haven't found anything yet on how to transmit the data from the car to the display's controller.
It's been a long time (a very long time, actually) since I last worked with assembly language.
Translated on 14-10-2026, 7:35.
Profile PM Garage |
Jan6K
30-03-2005, 16:58 Subject: TDI Signal Consumption Measurement 1Z |
Regarding data transmission: If you only need data like boost pressure, voltage, and temperatures, then connect it to your own sensors. This is likely to be much simpler and, above all, more reliable than tapping into the original sensor system.
Even a very small AVR microcontroller has enough analog inputs to easily handle this. Knowledge about controlling the LCD, etc., can be found, among other places, at www.mikrocontroller.net.
Jan.
1Z5 CFHF  / AHB H4D
Translated on 14-10-2026, 7:36.
Maik Guest
30-03-2005, 18:18 Subject: TDI Signal Consumption Measurement 1Z |
I completely agree with Jan on that.
But what about the signal for the power consumption display now  ?
Does anyone have any information about that?
Sure, here's the translation:
'Best regards,' or 'Sincerely,'.
Maik.
Translated on 14-10-2026, 7:37.
wolfi_b Profi-Schrauber
wutz Blaumann
31-03-2005, 6:52 Subject: TDI Signal Consumption Measurement 1Z |
I also have a link here that might be interesting. People have also looked into this (although in a somewhat more extreme way).
http://forum.fueldner.net/viewtopic.php?t=618&start=0&sid=f9992679de32c49c9382a887c9887d88
"The link is a bit long."
Translated on 14-10-2026, 7:38.
Profile PM Garage |
Maik Guest
31-03-2005, 8:23 Subject: TDI Signal Consumption Measurement 1Z |
Okay, now I know that the consumption signal is a PWM signal. Let's see if I can figure out how it relates to the actual consumption.
Thank you very much.
Maik.
31-03-2005, 10:04 Subject: TDI Signal Consumption Measurement 1Z |
That refers to the AAZ => Unfortunately, it's completely unusable.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 14-10-2026, 7:39.
Maik Guest
31-03-2005, 11:54 Subject: TDI Signal Consumption Measurement 1Z |
There is some information about the consumption signal from the 1Z.
http://www.audifaq.info/viewtopic.php?t=309&highlight=bc+tdi&sid=827a133d21f7d6265eb4bb85118b4e12
Perhaps the author can also help you a little bit.
How can I sign up for the website? I unfortunately can't find a registration button under http://www.meckisfaq.de/.
Maik.
Translated on 14-10-2026, 7:40.
Günther Guest
31-03-2005, 11:57 Subject: TDI Signal Consumption Measurement 1Z |
Try it using: http://www.meckisforum.de/
Günther.
Maik Guest
31-03-2005, 12:07 Subject: TDI Signal Consumption Measurement 1Z |
Günther
Sure, you're welcome.
Translated on 14-10-2026, 7:41.
Maik Guest
05-04-2005, 7:09 Subject: TDI Signal Consumption Measurement 1Z |
Hello, I was just about to measure the power consumption signal and unfortunately discovered that pin 9 of the control unit, where the signal should be present, is not connected. No one at VW could give me a part number for a repair wiring harness. Does anyone here have a part number for a connector for an engine control unit from a VW 1Z, year of manufacture 1994, with engine code 028906021C?
Maik.
Translated on 14-10-2026, 7:42.
