AFN All-Wheel Drive: Pre-Pump Issues?
AFNTDI1,9
Post01-04-2005, 22:42    Subject: AFN All-Wheel Drive: Pre-Pump Issues? Quote
Hello!
A fuel sensor from a PD TDI engine was incorrectly installed in my AFN VP TDI 81KW engine!
I have, however, changed that circumstance icon_cool.gif now.
Well, my actual question is:
What type of pre-charge pump is installed in the all-wheel drive system?
According to the wiring diagram, there must be one...
I wouldn't be entirely unhappy about a small discussion group icon_smile.gif.
I had a problem with my previous car, a Passat B4 TDI 1Z with 66 kW, where it would constantly stop working due to a lack of diesel, even when it was before the reserve level.icon_sad.gif
It's not a pressing issue, but I'm interested in it icon_wink.gif.
Best regards.
Translated on 12-10-2026, 15:35.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post02-04-2005, 0:02    Subject: AFN All-Wheel Drive: Pre-Pump Issues? Quote
This is not a pre-filter pump; it's just a pump that feeds the dust container (collection container).
It always needs to be full, otherwise the front pump won't work properly.
In all-wheel-drive vehicles, the fuel tank is divided into three separate compartments. Therefore, a pump is installed to ensure that the fuel is always supplied to the fuel tank pickup.
B.Eng (FH) u. KFZ Meister
Translated on 12-10-2026, 15:37.
AFNTDI1,9
Post02-04-2005, 8:41    Subject: AFN All-Wheel Drive: Pre-Pump Issues? Quote
That means the fuel tank is split so that the rear axle has enough space for the all-wheel drive system.
"Does anyone have any ideas, looking back (the car has already been sold, but I'm still curious), why my B4 always seemed to struggle a little bit when the fuel gauge was just above the reserve mark?"
No new posts Parking brake - All-wheel drive Diesel Engine Technology
No new posts ARL TDI 4x4: My Experience with the 1.9 TDI 150 HP Engine Diesel Engine Technology
No new posts Passat AWD Transmission Failure: Causes & Repair Diesel Engine Technology
No new posts Coding Golf4 TDI all-wheel drive and 2WD in the engine co... On-Board Diagnostics (OBD)
