haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
11-04-2005, 10:11 Subject: Brake Maintenance: How to Protect Your Brakes |
Hello fellow enthusiasts,
Our Audi sits idle every year in February for 4 weeks, and after this period, the brakes are always so rusted that it's difficult to hold the steering wheel when braking  -> new rotors. The contact surface of the brake pad on the rotor is particularly damaged, which causes the vibrations. Is there a way to prevent this? I'm sure lubricating the brake disc with oil won't work  . ____________
Kein Auto mehr!
Translated on 17-08-2026, 21:56.
rinderwahnsinn Guest
11-04-2005, 11:28 Subject: Brake Corrosion Protection: How To & Tips |
It actually works great. You just have to remove them beforehand...
If the vehicle is parked outside, there's not much you can do to prevent rust.
One approach would be to wrap the wheels in plastic bags, place silica gel packets inside, and seal them as tightly as possible.
Sure, here's the translation:
'CU' is an abbreviation for 'see you.' It can be used in a variety of contexts, such as:
* In text messages or emails to say goodbye.
* At the end of a phone call or video chat.
* When leaving a meeting or event.
* As a casual way to say hello when arriving somewhere.
'CU' is often used by people who are close friends or family members, but it can also be used in more formal settings.
Translated on 17-08-2026, 21:58.
haehnlein Schrauber
11-04-2005, 13:32 Subject: Brake Corrosion Protection: How To & Tips |
rinderwahnsinn wrote: | | You just have to take them out beforehand... |
Well, if I calculate the cost of the new brake discs based on my hourly wage, they turn out to be cheaper.
rinderwahnsinn wrote: | | One approach would be to wrap the wheels in plastic bags, place silica gel packets inside, and seal them as tightly as possible. |
Then the question is how much water condenses under the plastic film. But even so, it's probably a good thing that road salt spray isn't getting splashed onto the rims. The road salt used in February is certainly the main cause of rust. ____________
Kein Auto mehr!
Translated on 17-08-2026, 22:00.
11-04-2005, 17:52 Subject: Brake Corrosion Protection: How To & Tips |
Then the question is how much water condenses under the film.
Translated on 17-08-2026, 22:02.
haehnlein Schrauber
11-04-2005, 18:49 Subject: Brake Maintenance: How to Protect Your Brakes |
Okay, so it seems there are large bags of silica gel available... What is the price? ____________
Kein Auto mehr!
11-04-2005, 19:11 Subject: Brake Maintenance: How to Protect Your Brakes |
Good question...
'I pick them up every time when the goods are received. They also come in 500ml packs. We have to put them in the oven first, but then they work really well.'
Translated on 17-08-2026, 22:03.
golfschrauber1981 Guest
11-04-2005, 19:49 Subject: Brake Maintenance: How to Protect Your Brakes |
Haehnlein wrote the following:
Well, if I convert the working hours into money, the new brake discs are cheaper...
Yes, but you also have to remove the old panes and install new ones. So, that calculation doesn't quite work out, does it?
Translated on 17-08-2026, 22:04.
haehnlein Schrauber
11-04-2005, 23:47 Subject: Brake Maintenance: How to Protect Your Brakes |
golfschrauber1981 wrote: | | Yes, but you also have to remove the old windshields and install new ones. So, that calculation doesn't quite work out, does it? |
Hi Golf Schrauber,
Sure: That might be true in a garage or workshop, but not for someone working on the road  . A lot of time is wasted getting the heavy jack and tools out on the street. The wheel must essentially be completely mounted twice, and it hangs from the axle without a disc during the downtime (I can't leave the jack(s) outside under the car for four weeks...). A better option might be to remove the brake pads and then lubricate the disc. ____________
Kein Auto mehr!
Translated on 17-08-2026, 22:05.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
12-04-2005, 10:52 Subject: Brake Maintenance: How to Protect Your Brakes |
Why don't you simply park the car in a dry, well-ventilated place, such as a parking garage?
Translated on 17-08-2026, 22:07.
Profile PM WWW Garage |
haehnlein Schrauber
12-04-2005, 10:59 Subject: Brake Maintenance: How to Protect Your Brakes |
Rainer K. wrote: | | Why don't you simply park the car in a dry, well-ventilated place, such as a parking garage? |
Hi Rainer,
Unfortunately, that doesn't exist where my parents live in the countryside.  ____________
Kein Auto mehr!
Julian Guest
12-04-2005, 11:19 Subject: Brake Corrosion Protection: How To & Tips |
A possible approach would be to wrap the wheels in plastic bags, place silica gel packets inside, and seal them as tightly as possible.
muhahahaha... just get a Hamerit product; it already includes a rust converter. And 'colorful = creative' is also part of the package.
This stuff even holds together rusted, flaking metal... In my experiment on the house, it lasted at least 3 years... but you probably won't be on vacation for that long.
If I were you, I would get what are called 'car condoms.' They prevent rain from getting in and also allow for good ventilation.
Translated on 17-08-2026, 22:08.
haehnlein Schrauber
12-04-2005, 12:19 Subject: Brake Corrosion Protection: How To & Tips |
Julian wrote: | But you probably won't be on vacation for that long, will you? |
It's not me, but my parents are away for that long every year on business trips. ____________
Kein Auto mehr!
Translated on 17-08-2026, 22:10.
