Golf 4: Speedometer Coding - Not Changeable!
Julian
Post24-04-2005, 11:28    Subject: Golf 4: Speedometer Coding - Not Changeable! Quote
Hello!
Golf 4 speedometer, gasoline engine, MMO, part number 1J0 919 860.
Encoding 00141 should be changed to 00144.
Unfortunately, that's not possible. The speedometer is not accepting the new coding.
Sure, here's the translation:
'Any hints? Login required?'
Translated on 24-10-2026, 19:46.
edazer
Post24-04-2005, 18:22    Subject: Golf 4: Speedometer Coding - Not Changeable! Quote
Look http://de.openobd.org/vw/golf_1j.htm#17.
and you will see that 'xxxx4' is not being encoded.
edz
Julian
Post24-04-2005, 18:40    Subject: Golf 4: Speedometer Coding - Not Changeable! Quote
1 - 4358 (1,4l/55kW AHW/AKQ mit Schalt. Transmission.
2 - 3538 (for all other engine codes or automatic transmissions).
3 - 4146 (1,6l/74-77kW und 1,9l/50kW-SDI mit Schalt. Transmission.
4 - 3648 (unknown)
Why? xxxx2, xxxx3 doesn't work either... or rather, nothing works. But thank you for the attempt... icon_smile.gif
Translated on 24-10-2026, 19:47.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post26-04-2005, 7:45    Subject: Golf 4: Speedometer Coding - Not Changeable! Quote
If I've understood correctly, there are speedometers with a fixed K-value. It seems that this value cannot be changed. This might be the case with yours.
As a supplement.
4 = 3648 = all engines with a 6-speed manual transmission or a 5-speed automatic transmission.
Translated on 24-10-2026, 19:48.
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic coding not changeable? On-Board Diagnostics (OBD)
No new posts Coding Golf4 TDI all-wheel drive and 2WD in the engine co... On-Board Diagnostics (OBD)
No new posts Golf 4 AHF won't start - Troubleshooting Diesel Engine Technology
No new posts Speedometer adjustment, NO, not the odometer display :) Diesel Engine Technology
