Golf 3 1Z Engine: Fits Audi 80 B4?
PaPa
Post18-04-2005, 16:00    Subject: Golf 3 1Z Engine: Fits Audi 80 B4? Quote
Hello.
After searching for over an hour here on the forum, I'm going to ask about it.
Does anyone know if the 1Z engine from a Golf 3 will also fit into an Audi 80 B4?
I had a seized piston in my engine and now I'm looking for a new engine block.
'On the **** platform, someone is selling TDI engine blocks. I called them, and they said that these blocks only fit cars where the engine is mounted transversely (sideways).'
Since the 1Z engine in my B4 is installed longitudinally, these blocks wouldn't fit.
Here is the link again: http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=7968793992
Thank you in advance!
Translated on 30-09-2026, 11:02.
faz
Avatar-faz
1994 Audi 80
Post18-04-2005, 21:57    Subject: Golf 3 1Z Engine: Fits Audi 80 B4? Quote
To my knowledge, the front and side blocks are slightly different.
There will still be a block for the B4; for example, check out this link:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=7968487593
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 30-09-2026, 11:03.
Wolfgang, syncro16
Post19-04-2005, 23:53    Subject: Golf 3 1Z Engine: Fits Audi 80 B4? Quote
Hello Dad,
A transverse engine block has a different hole pattern on the right side (when viewed from the direction of travel) of the engine mount bracket compared to a longitudinal engine block. Therefore, your engine mount will not fit.
If you want to know more about other differences, you might find something else under [a specific section/link/heading].
http://www.meckisfaq.de/viewtopic.php?t=119 But that's about the AFN and about more than just the block.
Hello.
Wolfgang.
Translated on 30-09-2026, 11:04.
No new posts Rotating Rear Wiper Nozzle for VW Golf 4, Audi A3 8L Troubleshooting & Guides
No new posts Audi A3 8L, Golf 4 etc. - Turn signal relay is malfunctio... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV ALH: Does G60 flywheel & clutch fit? Diesel Engine Technology
No new posts Does this rim technically fit on a Golf V? Transmission, Chassis, Body & Interior
No new posts Does this catalytic converter fit a Golf with a 1Z engine? Diesel Engine Technology
No new posts Does this connector fit a Volkswagen Golf 4? On-Board Diagnostics (OBD)
