AUDI AEL: Can Needle Lift Injector Work with 850TDI?
morti850tdi
Post16-09-2004, 8:00    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
The Volvo 850 TDI is powered by an engine that actually originates from Audi, where it is known as the AEL.
The 4 standard fuel injectors have the same part number from Bosch, but the injector with the needle lift actuator does not.
Is this just marketing, or what? Shouldn't the NHG (New Hardware Generation) also apply to the Audi, since it's the same engine?
Morti.
Translated on 12-10-2026, 15:28.
Rudi
Post16-09-2004, 8:35    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
Hello Morti,
Technically, the parts should be identical.
I can imagine that Volvo (or Bosch, for Volvo) ...
installed a different plug.
If you could take a picture of the plug, that would be helpful.
Best regards, Rudi.
Translated on 12-10-2026, 15:29.
morti850tdi
Post18-04-2005, 19:49    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
The plug is the same, but the cable length is different.
The Volvo injector nozzle holder kit comes with a cable that is only about 20cm long, while the Audi kit has a cable that is approximately 1 meter long!
So, it's not a problem to use the NHG nozzle holder from a Volvo in an Audi.
This is also interesting because Volvo and Bosch no longer offer replacement injector holders, which makes replacing them very expensive. Audi still offers replacement injector holders, which is about 600-700 euros cheaper.
Translated on 12-10-2026, 15:30.
lappen
Post18-04-2005, 20:03    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
But be careful! I've found that the parts specialists are very particular and only accept direct replacements. In other words, if you come with a different part number, the exchange may be difficult or even impossible.
Translated on 12-10-2026, 15:31.
MichaC.
Karma: +9 / -0   Thank you, like it!
Post18-04-2005, 21:11    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
lappen wrote:
But be careful! I've found that the parts staff are very particular and only accept direct replacements (1:1). In other words, if you come with a different part number, the exchange may be difficult or even impossible.
And that's perfectly justified! The dealer gets the parts credited back if the original part and the replacement part are not identical! We've had quite a few issues with that in our warehouse. That's why the guys are now being extra careful.
"Micha"
Seat Toledo (1L) Bj.98 AFN 0.216er Düsen, VNT-17 Lader, 1,2bar Ladedruck, Speedbuster-Box, langer 5.Gang -- bis 03.06
VW Bora Variant Sport Edition Bj.02 AJM mit ******** OBD Tuning -- ab 03.06
Translated on 12-10-2026, 15:32.
audi-quat
Post22-04-2005, 7:36    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
Can you buy fuel injectors for a Volvo? If so, are they cheaper than those for an Audi? Or should you order them directly from Bosch?
Rob
Translated on 12-10-2026, 15:33.
morti850tdi
Post22-04-2005, 9:29    Subject: AUDI AEL: Can Needle Lift Injector Work with 850TDI? Quote
As mentioned before: Bosch and Volvo only offer the injector holder combinations as complete new sets and do not accept the old ones as trade-ins. The cost for all 5 injector holders is approximately 1300 euros!
Theoretically, it might be possible to install Volvo fuel injectors in an Audi AEL, but with the NHG injector holder combination used in Volvos, the cable is too short.
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts VW/Audi Recall: Important Safety Notice Diesel Engine Technology
This topic is locked, you cannot edit or reply. Audi A4 GRA AJM - Solved Problem On-Board Diagnostics (OBD)
No new posts Audi A6: P2002 Error Code & Fixes Diesel Engine Technology
No new posts Audi A3: Electric Window Problem & Repair Transmission, Chassis, Body & Interior
