Folding key is failing
denni
Post28-04-2005, 10:02    Subject: Folding key is failing Quote
Hello! I'm having a problem with my key fob (3 buttons) for my Passat (year 2001). It seems to be weakening, meaning I can no longer unlock the doors remotely from at least 10 meters away.
Now, however, it only goes for a maximum of 2 meters beforehand. icon_rolleyes.gif
What could be the reason icon_question.gif?
I have already changed the battery icon_exclaim.gif.
Maybe one of you has experienced the same problem before and can tell me what caused it.
It must be something wrong with the key because the other spare key works perfectly fine.
Thank you very much icon_wink.gif.
Sasnad
Post29-04-2005, 9:34    Subject: Folding key is failing Quote
It most likely has to do with a broken connection. These things sometimes fall and get damaged, you know? Reflow the solder joints and it should work again! It has always helped me.
Best, Sascha.
No new posts Audi Folding Key with 2 and 3 Buttons Compatible? Transmission, Chassis, Body & Interior
No new posts Golf 3 TDI: Install Key Fob Remote Control On-Board Diagnostics (OBD)
