Measure oil temperature using MFA
Post22-04-2005, 20:15    Subject: Measure oil temperature using MFA Quote
Hello!
I would like to install an oil temperature sensor in a friend's 1998 AFN Passat with air conditioning, at the oil filter flange housing there is a blind plug, where the sensor can fit. However, is it possible to display the oil temperature in the MFA (Multi-Function Display)? I was thinking of replacing the outside temperature display with the oil temperature, and since the air conditioning also displays the outside temperature anyway, it would be a good solution. Is there a possibility to reattach it?
edgar-s
Post27-04-2005, 11:01    Subject: Re: Measuring Oil Temperature with MFA Quote
... I think that if both donors have the same characteristics, i.e., the same resistance, it should work - however, it is questionable whether Temp > 50 is considered implausible and perhaps not displayed.
Post27-04-2005, 20:10    Subject: Measure oil temperature using MFA Quote
Due to the plateau function of the display, the result will hardly be usable...
Jan6K
Avatar-Jan6K
Post27-04-2005, 20:45    Subject: Measure oil temperature using MFA Quote
He wants the outside temperature display, not the water temperature. So, there isn't a plateau function... but I have my doubts about whether the outdoor temperature display will reach 130 degrees or so.
Jan
1Z5 CFHF / AHB H4D
Post27-04-2005, 22:22    Subject: Measure oil temperature using MFA Quote
Okay, I missed it.
But also, keep in mind that the outdoor temperature won't rise as high.
Post01-05-2005, 11:02    Subject: Measure oil temperature using MFA Quote
Okay, I've tested it: I warmed up the outdoor temperature sensor with a hairdryer for 30 minutes, and the result is that the temperature only shows slightly more than 21°C. I suspected that there must be another sensor, so I removed the pollen filter, but there's no sensor there! Is there a wiring diagram showing how to add an oil temperature sensor retroactively? On some Passats, the oil temperature is displayed in the MFA. Can the MFA be unlocked? A schematic diagram would be very helpful!
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Temperature Sensor AEL C4 Diesel Engine Technology
No new posts Higher Oil Temperature: Causes & Solutions Diesel Engine Technology
No new posts ALH engine: Oil temperature too high? Diesel Engine Technology
No new posts Retrofitting AFN engine with 028 906 021, including oil t... Electrical Systems, Vehicle Electronics, Multimedia
