Problem with Passat Climatronic 1996
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
josip77
Post29-05-2005, 13:03    Subject: Problem with Passat Climatronic 1996 Quote
I have installed a Climatronic system from a Passat 96' 2.0 16V (VAG number 3AO907044A) into my Passat 94' TDI, which has the part number 028906021B. The problem is that when the engine first starts, the compressor doesn't engage until the car reaches 25 km/h. After that, the compressor works fine even when the car isn't moving. Is it possible to fix this so that the compressor engages when the engine starts? There are no fault codes in either the Climatronic system or the engine.
Translated on 17-07-2026, 19:53.
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem in der Climatronic T4 Multivan On-Board Diagnostics (OBD)
No new posts Mechanical Problem Climatronic Transmission, Chassis, Body & Interior
No new posts Climatronic Passat 3B Transmission, Chassis, Body & Interior
No new posts Hat wer Stromlaufpläne für die Climatronic vom Passat 35i? Diesel Engine Technology
