Golf Tiptronic: Info & Steering Wheel Paddles
pschaefer
Post21-08-2002, 8:24    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
Hello!
I'm considering a Golf with a 96 kW engine and Tiptronic transmission.
Unfortunately, the salespeople don't seem to know anything about it.
Tiptronic ("Yes, in the Passat, we have something like that").
Does anyone know more? How many control programs?
Grading, sensory perception, etc.?
"Furthermore, I saw that there are options available for the Audi A3."
With Tiptronic, available at a very reasonable additional cost, and steering wheel controls.
gibt; beim Golf sind die nicht zu haben. Can you...?
Can it possibly be retrofitted with an Audi replacement part in a Golf?
And one more thing: When it comes to chip tuning, they also want to adjust the...
Reprogram the automatic control electronics, for example.
for a whopping 302 euros.
What are they doing?
Best regards and thank you!
Peter.
Translated on 18-09-2026, 20:35.
Tobias
Post22-08-2002, 11:15    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
Hi pschaefer,
If I'm not mistaken, the Passat PD with 130 horsepower has an automatic transmission.
from us (specifically, from the Zf).
If that's the case, it's a 5-speed automatic transmission with a manual shift gate.
'This means 5 gears with a standard driving program, a sport program, and manual gear selection.'
Maximum torque design: 350 Nm.
Front-wheel drive, longitudinal.
Hydrodynamic torque converter with an integrated, controlled torque converter lock-up clutch.
Five-stage planetary gearbox.
Integrated differential.
Transmission capacity:
Tmax at 3500 rpm: 310 Nm.
Pmax at 5500 rpm: 230 hp.
Nmax 1-4 gears: 6540 RPM.
Nmax 5-speed: 5000 RPM.
Please provide the German text you would like me to translate into English.
1st gear, 3.67.
2nd gear, 2.00.
3rd gear, 1.41.
4th gear, 1.00.
5th gear, 0.74.
R Gear 4.10
Weight with oil (lifetime fill): 109.5 kg.
Okay... that's it... I think.
I hope this helps you.
Greetings from Lake Constance.
Tobi.
Translated on 18-09-2026, 20:38.
Varianti
Post22-08-2002, 11:34    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
109 kg? And that's just for the transmission? That's not a truck! icon_eek.gif
I can't quite believe that. Is that really true? I would estimate a maximum of 40 kg.
Translated on 18-09-2026, 20:41.
Tobias
Post22-08-2002, 11:42    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
Hi there!
No, no, that's right... 109.5 kg with lifetime oil fill!!!
Tobi.
pschaefer
Post22-08-2002, 12:39    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
Thank you for the detailed answer!
I actually wanted to know it for golf, but...
It was probably the same gearbox.
And considering the weight, I'm not surprised anymore.
wo der spezifizierte Mehrverbauch ggü. Manual transmission.
...is where it *really* comes from...
Hmm. 350 Nm of torque, which leaves plenty of room for tuning.
That's enough. I'd better stay away from that.
How quickly does a gear shift occur?
Translated on 18-09-2026, 20:42.
pschaefer
Post22-08-2002, 12:51    Subject: Golf Tiptronic: Info & Steering Wheel Paddles Quote
Jetzt hab' ich mal schnell den DZR angeworfen. Okay.
when translating the 5th gear and 195/65 tires.
At 3200 RPM, that's approximately 160 km/h.
Mein jetziger 85 kW PD mit 6-Gang macht im 6. Sure, here is the translation of the text from German to English:
"Gang bei" translates to "gang at" or "gang near" in English.
3200 RPM is approximately 175 km/h. Therefore, the Tiptronic transmission has a slightly shorter gear ratio.
translated; so, all of them... Well, I guess I'll still do it.
take...
Does anyone know if the axle reduction gear included in the DZR (Differential Zahnradgetriebe - Differential Gearbox) is...?
"Is 3,158 a reasonable price for a Golf IV, or am I wrong?"
Did you calculate something completely wrong?
Translated on 18-09-2026, 20:44.
No new posts Einige Infos zum Kältemittelöl Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts General information about PD testing for troubleshooting ... Troubleshooting & Guides
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV Tiptronic: Max. Torque & 5-Speed Options Diesel Engine Technology
No new posts TDI Engine Conversion for VW T3: Info & Docs Diesel Engine Technology
No new posts Transponder Immobilizer: Info & Details On-Board Diagnostics (OBD)
No new posts Infos zum neuen Piezo PD System Diesel Engine Technology
