Audi A3 8P: Rear View Camera Issues
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post12-11-2017, 19:58    Subject: Audi A3 8P: Rear View Camera Issues Quote
Sunday, November 12, 2017, 13:47:01:26778
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 8.1 x64.
VCDS Version: RKS 17.8.0.1 HEX-V2 CB: 0.4408.4
Data as of: 20171026 DS276.6
Vehicle Identification Number: WAUZZZ8P8AB022687. License plate: [Missing information]
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 62: Door electric strike, left/right.
Label file: DRV\8P4-959-801.lbl
Control unit part number: 8P4 959 801 F. Hardware: 8P4 959 801 F.
Component and/or version: Door module SG, H04 0050.
Encoding: 0131216
Operating number: WSC 00046 412 1012544
VCID: 42DE4065888958B70DE-8016
"One error found:"
01554 - Motors for rear central locking doors; LOCK.
012 - Electrical fault in the circuit.
Address 72: Door electric strike, high, right.
Label file: DRV\8P4-959-802.lbl
Control unit part number: 8P4 959 802 F. Hardware: 8P4 959 802 F.
Encoding: 0131216
VCID: 43D04561979351BF068-8016
2 error codes found:
00931 - Rear right central locking latching unit (F223)
008 - implausible signal.
What do you think? Should I check the wiring harness to the door, or should I just remove the door panel?
Translated on 17-09-2026, 3:00.
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post12-11-2017, 21:42    Subject: Audi A3 8P: Rear View Camera Issues Quote
Hello.
Have you ever looked at the material weight breakdown (MWB) for doors?
It might be possible to determine if the microswitches are still working or if the signals change when you open and close the door, or when it is closed/open.
Regards, Mpire.
Translated on 17-09-2026, 3:04.
Post12-11-2017, 22:08    Subject: Audi A3 8P: Rear View Camera Issues Quote
Good idea!
Post13-11-2017, 10:00    Subject: Audi A3 8P: Rear View Camera Issues Quote
Hi Rainer,
Have you checked the SLP to see if the rear doors share a common "lock" connection?
If that were the case, I would suspect a fault on the right rear side, which would be correctly detected on both the right and left sides.
Greetings.
Guste.
Translated on 17-09-2026, 3:05.
No new posts Audi 8P documentary: The rear bumper/spoiler has a wavy s... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action Polo MJ 2000, rear brake hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Immobilizer Malfunction: Fix It Now! Diesel Engine Technology
No new posts Audi A6 is behaving erratically, could it be the electron... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A3 Rear License Plate Screws 8PA Transmission, Chassis, Body & Interior
No new posts Audi A2 conversion to disc brakes at the rear Transmission, Chassis, Body & Interior
