Coolant Leak Audi A4 AFN: Causes & Fixes
oldewurtel
Post27-05-2005, 11:16    Subject: Coolant Leak Audi A4 AFN: Causes & Fixes Quote
Dear fellow enthusiasts,
My A4 has been experiencing a slight, intermittent coolant leak (pink stains in the garage icon_mad.gif) for some time.
It was accompanied by increasingly frequent 'gurgling' sounds in the heating heat exchanger. Of course, instead of coolant, there was now air in the system. Bleeding the system provided a temporary improvement.
As described in the forum on several occasions, the engine was running dry after a longer and more demanding drive. The next morning, there were occasional instances of the infamous pink spots.
In my case, it was the O-ring on the temperature sensor, but I also replaced the flange at the same time.
Tip:
Since O-rings and hoses are difficult to install when dry, I use hot water grease from the sanitary area for this purpose. Applied in a very thin layer, the hoses slide easily over the connections.
Is there anything better, or are there any objections to using icon_eek.gif ???
The pictures speak for themselves.
 Der O-Ring ist an der Dichtkante "verschmiert"
 File size:  111.06 KB
 Viewed:  3063 times
 Ich war einmal ein O-Ring.
 File size:  75.64 KB
 Viewed:  2949 times
Translated on 26-08-2026, 22:39.
hb2000
Post27-05-2005, 14:52    Subject: Coolant Leak Audi A4 AFN: Causes & Fixes Quote
'My Passat has been making a bubbling noise for 30,000 km now, and I'm also experiencing coolant loss. Perhaps the coolant is leaking out from the coolant temperature sensor, and it might not be the head gasket that's pushing exhaust gases into the cooling system.'
Translated on 26-08-2026, 22:41.
No new posts VW T6 TDI Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gradual Power Loss at High Mileage - Help! Diesel Engine Technology
No new posts Turbodiesel Failure: VW Passat 2.0 - Symptoms & Causes Diesel Engine Technology
No new posts Coolant Leak Golf 5 2.0 BKD Diesel Engine Technology
No new posts Coolant Leak: Connection to Combustion Chamber? Diesel Engine Technology
