Compression Measurement: Unlikely Results
jürgen2000
Post09-01-2018, 19:45    Subject: Compression Measurement: Unlikely Results Quote
Could it be possible for a PD diesel engine to have a compression pressure of over 50 bar?
I thought around 30 would be normal, right?
Jürgen.
Translated on 23-10-2026, 13:07.
Post09-01-2018, 19:53    Subject: Compression Measurement: Unlikely Results Quote
Possibly, a card with an inappropriate scale has been inserted. We can expect values around 30 bar. More important than the absolute value is that all cylinders provide approximately the same value. icon_wink.gif
Translated on 23-10-2026, 13:08.
jürgen2000
Post09-01-2018, 20:19    Subject: SEO: Best Practices for Website Optimization Quote
I was also thinking something similar!
Okay, here's the translation:
Thank you.
Jürgen.
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Compression Test VW/Audi 3.0 V6 TDI Diesel Engine Technology
No new posts VW Touran Turbo Sensor: Faulty or Inaccurate? On-Board Diagnostics (OBD)
No new posts Air Mass Meter (CFGB) - Implausible Reading Diesel Engine Technology
No new posts Exhaust Temp. Before DPF: Audi BRE Error Diesel Engine Technology
