Is chip tuning a worthwhile upgrade for a Golf 4 ALH 90 hp (2000 model)?
Benny
Post24-08-2002, 21:54    Subject: Is chip tuning a worthwhile upgrade for a Golf 4 ALH 90 hp (2000 model)? Quote
I'm new here and have a question about chip tuning for a 90 HP TDI Golf 4, manufactured in 02/2000, with engine code ALH.
Is it worth getting this engine chipped? Or does it significantly increase wear and tear on the machine?
My car now has 59,000 km on the odometer. It consumes very little oil, and I don't need to top it up within the 15,000 km oil change interval.
Has anyone installed a chip in this engine? How much power does it add? And what about repairs and durability?
Thank you for your reply. Best regards, Benny.
Translated on 09-07-2026, 7:21.
joop
Post25-08-2002, 21:16    Subject: Chip! Quote
Hello!
It definitely makes sense to get your car chipped. I've been driving cars with 'optimized' software for a long time. I can only recommend it. It's really fun, so go ahead and get the chip!
But would a 'real' chip be preferable to the PowerBoxes?
So, make sure you choose a reputable tuner. The one that promises the most power might not necessarily be the best. Also, consider factors like TÜV certification (German technical inspection), and warranty.
For more detailed questions, please ask.
P.S.
If you have questions about chip boxes, there is a detailed explanation of them on this website, so please read it there and don't post your questions here. (Otherwise, there will be another huge uproar, as we are all very emotionally attached to our own preferences!)
grezz
Translated on 09-07-2026, 7:23.
joop
Post25-08-2002, 21:21    Subject: Update! Quote
Hello!
I almost forgot about your other questions.
Wear and tear shouldn't be a problem unless you get a 'powermax' version. I'd say somewhere between 115-120 horsepower is achievable. Otherwise, you might encounter problems with the clutch and drivetrain.
If you also change the oil regularly, you're on the right track.
The top speed increases only slightly with the TDI engine, but you gain significantly more power at lower RPMs.
have fun and
grezz
Translated on 09-07-2026, 7:24.
Benny
Post25-08-2002, 22:04    Subject: Re: Additional information! Quote
'Wear and tear shouldn't be a problem unless you opt for a 'powermax' version. I'd say somewhere between 115-120 horsepower is within the realm of possibility. Otherwise, you might encounter issues with the clutch and drivetrain.'
I wanted to have the TDI engine chipped by Digi-Tec, with a warranty and dyno testing. So, the full package.
Yes, the vehicle has been regularly serviced according to the manufacturer's schedule by a reliable Volkswagen service center.
The oil used from the beginning is a 10W40 lightweight oil. I think it can be maintained at that level.
>The top speed increases only slightly with the TDI engine. However, you gain significantly more power at lower RPMs.
My TDI already runs surprisingly well, but it still has the standard chip. I'm almost as fast in terms of acceleration as the larger 110 hp TDI... which is strange, but it's true. Let's see what kind of results we get with a different chip on the dyno.
What is recommended: to conduct a pre- and post-test role-play, or just a post-test?
Best regards and thanks in advance, Benny.
Translated on 09-07-2026, 7:26.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Chiptuning: Keine verstärkte Kupplung für Golf IV TDI ALH? Diesel Engine Technology
No new posts Clutch slipping after chip tuning (90hp) on a VW Golf IV ALH Diesel Engine Technology
No new posts Ki im 2000er Bora Spinnt On-Board Diagnostics (OBD)
No new posts Timing Belt Parts for 2000 AMF Diesel Engine Technology
