Hydraulic lifters or fuel injectors?
AchimTZR
Post10-05-2005, 18:00    Subject: Hydraulic lifters or fuel injectors? Quote
for a few months now, my AFN has been getting louder and louder... icon_evil.gif
(Mileage: 181,000 km)
This particularly noticeable hard running occurs during the warm-up phase, 1-2 minutes after cold start, everything sounds normal then.
My question:
What is more likely to be the cause? Could it be a faulty hydraulic valve (I performed a hydraulic valve test according to ****Win, but I couldn't detect any play)? Or could an injector be starting to malfunction? The engine performance is flawless, and I haven't noticed any strong smoking or other issues! Fuel consumption is also normal.
All of these facts seem to point to a faulty hydraulic valve to me.
What do you think? Do you have any experience with this? Has anyone else experienced this problem and been able to fix it?
What is the best way to proceed in this situation? Should I replace all of the needles and hope that it fixes the problem? I can't find any obvious issues with any of the needles...
Thanks in advance for your help.
Best regards, Achim
Golf III GTi TDi 20 Jahre AFN 81 kW
haehnlein
Post11-05-2005, 0:51    Subject: Re: Hydraulic lifters or fuel injectors? Quote
AchimTZR wrote:
How should one proceed in such a case?
Hello Achim,
try testing the injectors by disconnecting and reconnecting them one at a time while the engine is running (cold). If the tapping sound disappears, it's likely due to the specific injector. This method worked with the older Diesels, but I'm not sure what it means for the TDI, especially if you disconnect the line at the NHG. icon_confused.gif -> Wait for the professionals to handle the nozzles
It's not easy to determine the play in the throttle linkage. You need to press firmly on the linkage with a piece of wood and then carefully check if the linkage is sinking in. In our Audi, there was only very little play detectable after 270,000 km. However, replacing it led to smoother operation. If you're already planning to replace the timing belt soon, the investment won't be a problem (the cost is reportedly around 50 euros per set). Otherwise, I would just ignore it and not start the cold engine. icon_exclaim.gif
____________
Kein Auto mehr!
R.M.
Karma: +14 / -0   Thank you, like it!
Post11-05-2005, 9:01    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
Hallo.
@AchimViewing profile: Achim
Auf jeden Fall alle Hydros tauschen, falls die es sein sollten.
@ VW-Motoren-Profis
Gab es in einem GTI nicht mal verstärkte Hydros? Könnten die evtl. auch passen und etwas länger halten?
Gruß!
AchimTZR
Post26-05-2005, 12:49    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
bin gerade dabei alle Hydros zu tauschen, obs besser ist oder nicht werde ich heute abend wissen....
Preis für alle Hydros war 145,37EUR.
Achim
neubaupe
Post29-05-2005, 21:58    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]was passiert eigentlich, wenn man mit defekten bzw. 'ausgeleierten' hydrostösseln fährt ?
mfg. peter
rinderwahnsinn
Post30-05-2005, 6:46    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]Das kommt auf die Art des Verschleißes an:
- nichts
- Leistungsverlust weil Ventile nicht ganz öffnen
- Durchblasen weil Ventile nicht sauber schliessen (dabei geht meistens der Kopf drauf)
- starke Abnutzung von Schlepphebeln / Stösseln oder Nockenwelle
syncro peter
Post30-05-2005, 9:32    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]- ventile können durchbrennen
- motorschaden durch abschmelzenden teile
- kopfschaden incl. nockenwelle, wenn die hydros brechen
donalexo
Post03-06-2005, 19:00    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
@AchimTZR:
Hast Du die Hydros schon getauscht? Gib uns doch bitte Feedback, sobald Du ein Ergebnis hast!
Alex
Touran 1.9 TDI, EZ 09/2004
AchimTZR
Post05-06-2005, 16:50    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
so, die Hydrostößel sind drin.
Fazit:
Deutlich weicherer und runderer Motorlauf als vorher. Allerdings habe ich mir ganz ehrlich mehr davon versprochen. Mittlerweile vermute ich, das da wohl eine Einspritzdüse nicht korrekt in ihrer Führung sitzt.
Meines Wissens nach sind die Führungen der ESD recht eng aber trotzdem lassen sie ein gewisses "verdrehen" zu, was wohl den Klang des Motors erheblich verändern kann.
Das Tackern schiebe ich auf den ersten Zylinder, der fällt bei der Schraubendreher-Ohr-Methode am ehesten auf!
Aber ich kann jedem empfehlen sowas mal zu tauschen, wenn man mal 167 EUR zuviel im Geldbeutel hat icon_lol.gif
Auch angesichts der Laufleistung meines Motors von 185.000 Tkm ist das sicher mal angebracht, damit er noch lange morgens kraftvoll zubeißen kann icon_biggrin.gif
Im Übrigen gibt es für u.a. für den AFN in E*** 8 Hydrostößel zum Preis von lediglich 45 EUR ANGEBLICH ebenfalls von der Firma INA .
Klingt natürlich verlockend, allerdings hat sich mein Bruder dort mal so einen Satz bestellt. Das Ergebnis war ernüchternd: Die Bauform weicht von den Originalen ab und man kann nirgends ein Firmenlogo o.ä. auf den Stößeln sehen wie bei dem Satz von VW und wie bei denen die eingebaut waren.....
Also ist davon auszugehen das es sich mal wieder um "absolute Erstausrüsterqualität" handelt, wie so oft in E*** angepriesen! icon_evil.gif
Achim
donalexo
Post05-06-2005, 18:08    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
Hallo Achim!
Danke für Dein Feedback!
Wie lange hast Du für den Tausch der Hydros gebraucht? Hast Du die Reparatur mit dem ZR-Wechsel zusammengefasst (der ZR muss ja eh runter und die Nockenwelle raus)?
Sind Dir an den Hydros und/oder an der Nockenwelle irgendwelche übermäßigen Verschleißspuren aufgefallen?
Hast Du bei 185tkm noch die ersten Düsen drin? Dann halte ich allerdings die Theorie mit der schlecht ausgerichteten Düsenposition für zweifelhaft, da man die Teile normalerweise nur beim Ausbau löst.
Ist das harte Tackern in der Warmlaufphase jetzt auch abgemildert, oder haben die Hydros daran nichts geändert?
Alex
Taxiratte
Post07-06-2005, 17:21    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
Kenn mich mit den AFN nicht sonderlich aus, habe beim AJM ?(85KW PD) ein ähnliches Problem gehabt: Tackern beim Warmlaufen, später auch bei warmen Motor feststellbar.
Besuch in der Werkstatt, habe denen noch gesagt, sie sollen mal eben den defekten Hydro wechseln. Am Ende war es ein ausgelaufendes Hauptlager! Beim genauen Betrachten des Oels waren auch winzige Spänne erkennbar.
Meistens: Passat (1/00,1,9L, 85KW PD, 280tkm)
Abgemeldet: Passat 32B (11/88, 1,6L, 40KW, 550tkm)
AchimTZR
Post14-06-2005, 18:04    Subject: Hydraulic lifters or fuel injectors? Translating...
[Translating...]
erstmal sorry für meine späten Feedbacks, ich finde momentan selten die Zeit mal im Inet zu surfen...........
Den Zahnriemenwechsel habe ich ca. 5tkm vorher gemacht und mich erst später zum Tausch der Hydroß entschlossen! Übermäßgier Verschleiß an NW oder den Hydroß war eigentlich nicht zu erkennen.
Zeitlich war die Sache in 1 1/2 Stunden erledigt und verlief absolut problemlos.
Als nächstes stehen denn mal neue Einspritzdüsen an,die hat er sich bei der Laufleistung mal verdient icon_lol.gif
Achim
No new posts **Hydrostößel: Construction and Function** **Construct... Technical Articles
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Nockenwelle eingelaufen oder nur Hydrostößel?Späne im ... Diesel Engine Technology
No new posts Einspritzdüsen tauschen (selber machen / eine oder alle) Diesel Engine Technology
No new posts Defective Hydraulic Valves Diesel Engine Technology
No new posts Hydrostößel defekt? Diesel Engine Technology
