PLC Programming: Your Guide to STG Coding
Tobi12345
Post17-06-2005, 19:39    Subject: PLC Programming: Your Guide to STG Coding Quote
Hi everyone!
I have a question for everyone who knows more about engine control units (ECUs) than I do!
If a motor control unit (STG) is coded to "0003," which indicates all-wheel drive and the switch is working correctly, and the STG has been chipped, does the software only apply within this coding, or can I recode this STG to front-wheel drive automatic mode and still benefit from the advantages of the chipped software?
Thank you.
Tobi.
A6 Avant 3,0TDI Tiptronic Bj. 02/2008
Translated on 29-07-2026, 10:39.
Rudi
Post17-06-2005, 20:27    Subject: PLC Programming: Your Guide to STG Coding Quote
If only the data in the all-wheel drive module has been changed, then the performance increase will only be reflected there.
Rudi
Translated on 29-07-2026, 10:40.
Tobi12345
Post17-06-2005, 20:30    Subject: PLC Programming: Your Guide to STG Coding Quote
Do you know how tuners do it? Do they just modify the necessary map, like in this case, the all-wheel drive map?
Rudi
Post17-06-2005, 21:08    Subject: PLC Programming: Your Guide to STG Coding Quote
Yes - each person did what they considered to be right at the time the software was being created.
So... everything is possible.
Rudi
Translated on 29-07-2026, 10:41.
hb2000
Post20-06-2005, 11:39    Subject: PLC Programming: Your Guide to STG Coding Quote
If in doubt, simply try the other encoding - hopefully, your 'butt meter' will tell you whether there's an actual performance increase or not. You might end up with an error code if the communication between the engine control unit and the all-wheel drive control unit is no longer working.
Translated on 29-07-2026, 10:42.
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
No new posts STG-Codierung Diesel Engine Technology
No new posts Codierung MSG AKN On-Board Diagnostics (OBD)
No new posts Solved 90% BNS (BCM) T5.2 MDI and FSE coding? On-Board Diagnostics (OBD)
