Hello everyone,
I have a very strange problem and I'm hoping for some helpful advice.
Often, it's just an idea and the necessary experience that helps you move forward.
The following has been verified and ensured:
Please provide the German text you would like me to translate into English.
- Toledo, model year 1999, AFN engine.
- Manual air conditioning system, filled and leak-tested.
- Fuses 6 and 19 are in good working order.
- The magnetic coupling engages, but not always... see below.
Problem:
- AC switch off, fan set to 1 => fan does not run.
- AC switch off, fan on positions 2, 3, 4 => fan runs on positions 2, 3, 4.
- AC switch on, fan off => air conditioning off... which, in my opinion, is how it should be...
- Turn on AC switch, Fan 1 => Fan does not run, air conditioning is working.
- Turn on AC switch, fans 2, 3, 4 => Fans 2, 3, 4 are running, air conditioning is not running.
When the fan is set to position 1, I can turn the air conditioner on and off using the AC switch.
However, the blower is not starting up. In switch position 2, 3, and 4, I can use the AC switch.
Do not turn on the air conditioning. The magnetic coupling is not engaging.
Unfortunately, I don't have a wiring diagram for the air conditioning system or the vehicle. A pressure sensor.
shouldn't be the cause either, since the pressure levels in the air conditioning system are normal.
Has anyone experienced this "phenomenon" in a VAG vehicle with a manual transmission?
Did you have the air conditioning on, or does anyone have any other clever ideas, or perhaps...?
corresponding circuit diagram? The relationship between the various...
I'm also not entirely clear about the fan speeds and the air conditioning system. Okay, fan zero and...
Turning off the air conditioner makes sense, otherwise the evaporator would freeze completely, but what about...?
is it in gear 2, 3, or 4?
It would be really nice if someone could help.
Andreas...
