The Passat had a persistent rattling noise at the rear. Resolution
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Kanute
Post15-09-2005, 11:22    Subject: The Passat had a persistent rattling noise at the rear. Resolution Quote
"Ever since I bought my car, it's been making an annoying rattling noise on the right rear side, especially when driving over bumps. I cleaned out and checked the storage boxes to see if anything was loose inside, but there was nothing. I thought that if I had time, I would remove the rear panels, maybe I would find something underneath. Now, the car has had new shock absorbers installed in the rear, and the rattling is gone. I asked the workshop if they noticed anything. Their response was that the right rear shock absorber was completely incorrectly installed. A washer was missing, which caused a rubber bushing to slide downwards." And the previous owner told me: "Yes, it's true, it seemed to me that something wasn't right since the last suspension modification." icon_rolleyes.gif Well, he's a friend, otherwise the car is okay, and the price was reasonable.
Best regards.
Florian.
94er VW Passat 35i 1Z 302.520 km
Der Wagen steht aktuell (23.1.2013) zum Verkauf, TÜV 1/2013
Back to top Profile PM Email
Post15-09-2005, 11:48    Subject: The Passat had a persistent rattling noise at the rear. Resolution Quote
OK.
Here's a quick tip about potential variations to explore:
In my G3 variant, the bushings on the rear seatbacks have worn out. This causes them to rattle. The rattling noise disappears when the seatbacks are under pressure or simply latched together with the rear shelf.
I've already "filled" the compartments in the middle with tape. On the outside, they are just simple hinges, but inside, the plastic housings of the backrests rotate.
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Standheizung in Passat 3BG einbauen Troubleshooting & Guides
No new posts MFL Passat 3BG Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Engine Technology
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat TDI BJ 2002 mit Eur 3 ?? Diesel Engine Technology
