Hello!
I borrowed another Pierburg mass airflow sensor and logged the results (see the
Excel or
OpenOffice file). The Excel file was also created using OOO, and I cannot guarantee its accuracy (I don't have Windows here).
The values that the LMM (likely referring to a mass airflow meter) is providing are terrible, that's clear. But what I've noticed is that my desired airflow reading rarely exceeds 60, while according to the specification table, it should be 65-70 - which is also what I've seen in other logs here (they're usually around 69). Could this be due to the automatic transmission? The Drehmo limit seems to be "normal" again...
By the way: The value for the smoke limit in the target data table is incorrect, but
Roger has already noticed that.
Peter.
