windl Guest
28-06-2002, 10:24 Subject: Removing rear door panels on a Golf IV (5-door) |
I wanted to remove the rear door panel because the speaker is rattling, but I couldn't get it off. Besides the screws on the sides of the panel, which ones need to be removed?
Alchard Guest
28-06-2002, 22:08 Subject: Removing rear door panels on a Golf IV (5-door) |
Hi!
If it's similar to the Passat, then there should be two thick metal screws hidden under the handle cover...
Best regards - Alchard
fredi Guest
29-08-2002, 20:43 Subject: Removing rear door panels on a Golf IV (5-door) |
On the bottom side, there are 2 Torx screws under the handle cover. Remove 2 Phillips head screws. Pry off the cover from the bottom using a small flathead screwdriver. Then, disconnect it from the door and pull it away; it can sometimes be quite tight.
