René_S Guest
12-06-2005, 12:34 Subject: TDI Graph and AKN? |
Can I display the start of the injection on my AKN (likely referring to an engine control unit) using a TDI graph? The AKN cannot be selected in the MKB selection.
What comparable MKB (German classification system for occupations) codes can I use?
Thank you very much.
René.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
12-06-2005, 13:24 Subject: TDI Graph and AKN? |
The TDI timing tool is only for engines with a distributor injection pump.
Do you have a repair manual for the AKN?
Profile PM WWW Garage |
René_S Guest
12-06-2005, 19:32 Subject: TDI Graph and AKN? |
Hello Rainer,
I have a VP 44 and a repair manual. The injection start time, measured in the baseline program, is 2 or 14 degrees (duty cycle 23/100) - which is within acceptable limits.
The reason for my inspection is a louder-than-normal noise from the engine and a lack of power when the engine is cold.
René.
Steffarn Profi-Schrauber
18-06-2005, 22:52 Subject: TDI Graph and AKN? |
Okay, I find that the V6 TDI engines are always very noisy, especially when they're cold.
And if the operating temperature hasn't been reached yet, they don't perform as well either.
It's generally not good to rev a cold engine. B.Eng (FH) u. KFZ Meister
Profile PM Email Garage |
mserge Schrauber
Joined: 06/20/2005 Posts: 923 Karma: +6 / -0 Location: Luxemburg
13-07-2005, 16:03 Subject: TDI Graph and AKN? |
To the best of my knowledge, you can't do that with the graph. I have an AFB (presumably referring to a specific document or system), and I found the answer in the manual. I don't quite remember the exact procedure, but I believe it should be read using the data blocks, not the TDI graph. A4 Avant 2,5 tdi 110kw; AFB; BJ2000
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
