Corso di formazione - Motore AHU
dermoe
Messaggio21-06-2010, 20:22    Oggetto: Corso di formazione - Motore AHU Cita
Il mio AHU da 66 kW perde continuamente massa d'aria a partire da 3200 giri/min. A 4200 giri/min, ne perde solo 750 su 850 m³/h, e a 4600 giri/min solo 650 m³/h. Il rapporto di carico diminuisce già a 2800 giri/min, il che, a mio parere, è normale.
È questo andamento del motore normale o dovrei preoccuparmi di un motore bloccato/sensore di ossigeno difettoso?
PS: Il motore ha 270.000 km icon_biggrin.gif
Anbei die Log:
[codice],Gruppo A: '006,,,,Gruppo B: '003,,,,Gruppo C: '010
,,Freno-,Acceleratore-,Velocità-,nessuno,,Motore-,Aria-,Aria-,Tasto-,,Aria-,ambiente-,Tubo di aspirazione-,Pedale dell'acceleratore-
,TEMPO,velocità,pedale,tappetino,display,TEMPO,regime,massa,massa,rapporto,TEMPO,massa,pressione,pressione,posizione
MARKER,STAMP, km/h,,,,STAMP, /min, mg/R, mg/R, %,STAMP, mg/R, mbar, mbar,%
,63.41,30.0, 0 0 0, 000000,0.0,62.61,1197,320.0,498.8,43.0,63.01,422.3,999.6,1040.4,0.0
,64.61,32.0, 0 0 0, 000000,0.0,63.81,1176,850.0,498.8,4.8,64.21,515.4,999.6,1071.0,100.0
,65.81,39.0, 0 0 0, 000000,0.0,65.01,1386,850.0,585.2,4.8,65.41,645.1,999.6,1244.4,100.0
,67.12,48.0, 0 0 0, 000000,0.0,66.21,1701,850.0,741.5,4.8,66.66,791.4,999.6,1560.6,100.0
,68.51,58.0, 0 0 0, 000000,0.0,67.57,2100,850.0,847.9,4.8,68.05,847.9,999.6,1856.4,100.0
,69.79,68.0, 0 0 0, 000000,0.0,68.96,2478,850.0,847.9,4.8,69.39,847.9,999.6,1999.2,100.0
,70.99,76.0, 0 0 0, 000000,0.0,70.19,2814,850.0,847.9,4.8,70.59,847.9,999.6,1927.8,100.0
,72.19,84.0, 0 0 0, 000000,0.0,71.39,3129,850.0,841.2,4.8,71.79,841.2,999.6,1866.6,100.0
,73.39,91.0, 0 0 0, 000000,0.0,72.59,3423,850.0,804.7,4.8,72.99,804.7,999.6,1815.6,100.0
,74.62,98.0, 0 0 0, 000000,0.0,73.79,3675,850.0,798.0,4.8,74.19,798.0,999.6,1846.2,100.0
,75.95,104.0, 0 0 0, 000000,0.0,75.09,3948,850.0,784.7,4.8,75.55,774.7,999.6,1795.2,100.0
,77.15,110.0, 0 0 0, 000000,0.0,76.35,4179,850.0,764.8,4.8,76.75,758.1,999.6,1795.2,100.0
,78.35,114.0, 0 0 0, 000000,0.0,77.55,4368,850.0,721.5,4.8,77.95,698.3,999.6,1734.0,100.0
,79.55,118.0, 0 0 0, 000000,0.0,78.75,4515,850.0,671.7,4.8,79.15,665.0,999.6,1713.6,100.0
Messaggio21-06-2010, 21:52    Oggetto: Oggetto: Andamento della massa d'aria - Motore AHU Cita
dermoe ha scritto:
Questo percorso di controllo è corretto o dovrei preoccuparmi di un motore bloccato/un sensore di ossigeno difettoso?
Non mi ricordo più dei valori. Ma:
Controlla le quantità di iniezione nel MWB 8. Se la quantità di iniezione al massimo è sempre superiore al limite di coppia e non al limite di fumo (=conseguenza del valore misurato dal sensore di ossigeno), allora il sensore di ossigeno è funzionante. Se la quantità di iniezione viene ridotta al di sotto del limite di fumo, è necessario sostituire il LMM.
Saluti
Gusto
Nessun nuovo messaggio Cinghia di trasmissione a V con denti per T6 TDI con clim... Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Perdita di potenza: massa d'aria, pressione OK? Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Motore AJM: Rumore, Perdita Potenza, Fumo Nero Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Andamento temperatura dei gas di scarico vs. giri/minuto ... Tecnologia Motori Diesel
Nessun nuovo messaggio Si cerca parere di esperti sull'andamento della pressione... Diagnostica di Bordo (OBD)
Nessun nuovo messaggio Pressione sovralimentazione e massa d'aria Tecnologia Motori Diesel
Nessun nuovo messaggio Massa dell'aria troppo alta A6 4F 3.0 TDI ASB Tecnologia Motori Diesel
