Probleme mit GRA/Tempomat in Polo TDI 2002
ApFolmer
KFZ-Schrauber seit: 22.10.2010
Beitrag24-10-2010, 14:51    Titel: Probleme mit GRA/Tempomat in Polo TDI 2002 Antworten mit Zitat
Hallo.
(mein deutch ist nicht gut, so ich schreibt in english)
I just installed a tempomat in my Polo 9N 1,9 TDI 101 9N year 2002.
After installation, and activation with VCDS, it worked. (so far so good) ..
But, after installation of this, the car is running wierd. When putting it in gear, and clutching, it seems like the car needs more "gas-pedal" before reacting to this.
If i dont give it more "gas pedal" and slowly clutch, the car acts like if i dont give it enougf accelerator, and "limps" ...
Also, it seems like there is a "delay" of the accelerator/Gas pedal , and the acclerator does have most effect in the last 1/3 of the pedal...
Hope you understand me... plz help. My car is running like a bit of a Kangaroo, when the "stecker" is plugged in, for the Tempomat, when shifting gear.
No error on the Car with VCDS.
Nach oben KFZ-Schrauber-Profil anzeigen Private Nachricht senden Skype
Beitrag24-10-2010, 15:12    Titel: Probleme mit GRA/Tempomat in Polo TDI 2002 Antworten mit Zitat
first of all, no VCDS serial typed in (profile), second: VCDS scan would be helpful. Third:you did something wrong.
Best regards, Rainer
ApFolmer
Beitrag24-10-2010, 17:03    Titel: Probleme mit GRA/Tempomat in Polo TDI 2002 Antworten mit Zitat
1 : Seril will be entered in 2 secs icon_smile.gif
2 : VCDS shows NO errors. So this will not be helpfull.
3 : WEhat can go wrong, when the Tempomat works fine, only the speeder response has appeared ....
When unplugged, tha car drives fine..
Please help , what can be wrong, when the Tempomat works fine, but results in speeder-delay/response....
Keine neuen Beiträge Werkstattaktion Polo MJ 2002, Gurtführungsbügel Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge Doku Polo MJ 2002, Geräusche vom Getriebe Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge Tempomat Polo 6N2 Getriebe, Fahrwerk, Karosserie und Innenraum
Keine neuen Beiträge Tempomat im neuen Polo TDI nachrüsten Diesel Motorentechnik
Keine neuen Beiträge VAG COM findet ZV bei Polo 1,4 TDI (2002) nicht On-Board-Diagnose (OBD)
Keine neuen Beiträge Probleme beim Polo WRC On-Board-Diagnose (OBD)
