Spezial Steuergeräte
tomflyer
Beitrag18-11-2004, 19:12    Titel: Spezial Steuergeräte Antworten mit Zitat
Entschuldigung, meine Deutsch ist nicht so gut und deswegen möchte ich gerne auf English schreiben:
My hobby is to build flying machines. The newest one is going to be equipped with a car engine, a VW PD 1.9 DTI. At present I'm working with the mechanical parts (building a redrive to reduce the propeller speed). The next step will be the Electronics. The standard box, 'die standard Steuergeräte' is far more complex and complicated as it is needed in flight. I'm looking for some info or some assistance concerning data of this engine regarding beginning and duration of injection in different RPM and load ranges in connection to turbo pressure, air temperature and air volume etc. to be able the build a special box, very simple one, containing just the elementary functions for the engine, necessary to drive the propeller.
tomflyer
Avatar-Jan6K
Beitrag18-11-2004, 21:41    Titel: Spezial Steuergeräte Antworten mit Zitat
you want to build your own control computer for a PD engine? I guess that this is far more complex than adapting the original box to your needs by just removing sensors (and replacing their inputs by appropriate signals) and interconnections to other systems (such as immobilizer).
Btw... do you think this machine is powerful enough for your purpose? The ratio between power and weight is not that good with a TDI engine (compared to gas engines of same power).
Greetings,
Jan
1Z5 CFHF / AHB H4D
Beitrag18-11-2004, 23:38    Titel: Spezial Steuergeräte Antworten mit Zitat
in my eyes Jan is right.
The TDI is a very heavy engine. Please tell us what kind you flying mashine is. A supercharged engine is the best engine for reaching a high flight level. But isn`t a small Smart cdi engine the better choice?
Gremlin
Beitrag22-11-2004, 10:30    Titel: Spezial Steuergeräte Antworten mit Zitat
tom, you might use a engine with distributor pump like an 110hp AFN oder ASV.
it is possible to convert this engines to operate pure mechanical (but with much effort)
take a look at http://www.thielert.com/ and http://www.centurion-engines.com/
they have a flight-diesel certified to JAR-E
@jan
of course, a TDI is much heavier than a gasoline engine, but the fuel consumption is much lower. so you can compare the engine wight with less fuel icon_wink.gif
CU Gremlin
tomflyer
Beitrag23-11-2004, 10:43    Titel: Spezial Steuergeräte Antworten mit Zitat
Hello fellow Diesels,
Thank you for all the responses. My plane is BD-4 experimental, already built ready up to the fire wall, waiting for a suitable Diesel engine. I’ve broad margins regarding weight and power. The plane can be equipped with engines between 118-350 HP. First, as we are in Sweden, I've been intending to fit it with the Volvo D5 common rail, all of aluminium, even the block, 183 kg by 163 HP, a marvellous engine. However 5 cylinders plus the high pressure pump on the front, make the engine very long, resulting in that the PSRU (propeller speed reduction unit, weighing approximately 25-30 kg) is coming to a place far too much in the front. This fact can be compensated only by placing lead (dead weight) at the back of the plane as counterbalance to retrieve the essential Centrum of Gravity. That’s why I consider that a VW engine is more suitable. I’ve already made some sketches which show that the whole driving unit (engine and PSRU) can be placed under the original cowling made for a Lycoming engine. The penalties are: A relatively heavy engine, although it is lighter than the Volvo (the VW block is of cast iron, not of aluminium) and some less power, 130 HP versus 163. Hence I think the advantages are more. Presumably, the power of the VW can be screw up for a of couple of minutes to 150 HP for take off. As well the VW is much more shorter than the Volvo the balance weight in the back can be diminished or in best case completely eliminated and finally, the VW PD is representing the latest generation in Diesel technology contra Volvo which is a Common Rail. If you think of the fact that a Lycoming or a Continental engine of today doesn’t differ much compared to their 50 years old ancestors (except their selling price) you probably understand my endeavours. Gremlin has recommended the Thielert engine: They have of course possibilities and resources beyond all measures compared to myself. Thielert dismounts completely the brand new original (Mercedes) engine and with many modifications, rebuild it to a flight engine. The ready built and certified flight engine, called Centurion 1,7 rated to 135 HP, suitable for the private and commercial market. Their selling price is extremely high matching to the air market. As I personally am belonging to the group of home builders with moderate resources but with much enthusiasm Thielert is not the solution for me. My present plane with the VW Diesel is my third machine to build. Among us home builders there is very essential to keep down the costs. Therefore my policy is adopted to the experimental category: take a mass produced car engine and in doing so, utilise the latest technology and the acceptable purchase price. Gremlin proposes even to use the VW with distributor pump by 90 HP. As a matter of fact these older types of Diesels are not running as smooth as the ones with electronic injection resulting in serious torsional vibrations hardly disturbing in a car while most hazardous in flight. Regarding a car, the whole body, say about 1000 kg is acting as a linear flywheel damping resonances while in the air the same is replaced with the inertia of the propeller of some kgs and of the inpact of the air. On the other hand I’ve already bought a VW PD which has run just a couple of thousands km in a Passat. I’m not even intending to open the engine but the Steering Box can not be utilised just as it is. It would not have been strange to me to build another box containing the elementary functions only. However, Jan, alias “Jan6K” computer expert, is advising me to keep an original box and to block all the connections
(for instance ABS, EGR, immobiliser and so on) which are not needed in the air. Matthias, alias “MatthiasTDI96” agrees with him totally. Jan recommends for:
“adapting the original box to your needs by just removing sensors (and replacing their inputs by appropriate signals) and interconnections to other systems (such as immobilizer)”
As I do not have any box at present the one which I will purchase later, that has to be reprogrammed concerning the immobiliser functions as well. I’m going to be used more and more to apply an original box. The idea as such seems to be very practical and realistic and I would need some info concerning the same. Is there anyone of you who
can offer some assistance in this matter?
Regards
Tom
tomflyer7@hotmail.com
Keine neuen Beiträge EDC15 Steuergeräte, Software updatefähig Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge "Spezial"bauteil für AGR-Fake gesucht Diesel Motorentechnik
Keine neuen Beiträge 2 Steuergeräte im 1Z ? On-Board-Diagnose (OBD)
Keine neuen Beiträge Teilenummern AFN Steuergeräte.. Dieselschrauber Bar
Keine neuen Beiträge Steuergeräte Xenonscheinwerfer Dieselschrauber Bar
