Sealing a T3 Van (1986) - DIY Guide
Spaceballer
Karma: +1 / -1   Thank you, like it!
Post30-12-2006, 17:53    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
Hello everyone,
My acquaintance has an old T3 van with a 1.6TD "JX" engine.
Unfortunately, the VP (vacuum pump) is leaking at the quantity control valve, but I'm hesitant to disassemble the pump without instructions.
I'll probably need to replace the timing belt soon anyway, so I could get everything done at the same time.
Does anyone have a manual for the old pump?
"I would also be grateful for instructions on how to adjust the start time of the boost without using any special tools, if that is even possible..."
"Thank you in advance for your help..."
Translated on 30-09-2026, 14:08.
Held467
Post30-12-2006, 20:22    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
Hello.
Look over there.
http://www.uwereimann.de/poel/01_golfumbau.htm
Dirk
Translated on 30-09-2026, 14:09.
Post30-12-2006, 22:17    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
I would also be grateful for instructions on how to adjust the start of the boost without special tools, if that is even possible...
If the adapter and dial gauge are essential for you, then you can't do without them!
You'll need that stuff.
Spaceballer
Post30-12-2006, 23:55    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
@Held467Viewing profile: Held467:
Great instructions... thank you very much.
@dieselmartinViewing profile: dieselmartin:
I only have a dial indicator; I don't have an adapter.
Since I've never done this type of work before, a guide with photos would be very helpful so I can visualize the process better.
Sure, I would also need a photo of the adapter. Maybe someone could recreate something like that.
Translated on 30-09-2026, 14:10.
Post31-12-2006, 1:17    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
You can definitely build adapters yourself.
It needs to have an M10 thread and be hollow-bored for the JX, as far as I know. A corresponding long pin needs to be attached to the dial gauge, which then goes through the adapter into the ESP.
The whole thing looks like this.
http://i9.ebayimg.com/02/i/05/be/1e/1d_1_b.JPG
Instructions for this can be found in relevant literature, such as "Do-it-yourself" guides or "How-to" manuals.
You should only be relatively sure about what you're doing, because in the worst case, the car might not start, or you could end up causing even more damage.
Translated on 30-09-2026, 14:11.
Spaceballer
Post31-12-2006, 15:56    Subject: Sealing a T3 Van (1986) - DIY Guide Quote
Hello dieselmartin,
I found the picture on eBay.
Since I also need to replace the timing belt on my car soon, I did some searching on eBay and found several options...
I found a gasket for the pump for 13 euros, as well as the matching tool.
"Because replacing the timing belt on our car (Astra 1.7D) isn't straightforward, and you might have to adjust the fuel injection timing if you're unlucky, I also found a universal adjustment tool for Lukas and Bosch pumps from the same seller on eBay for 140 euros."
We have an automotive repair shop and have frequently replaced timing belts on both diesel and gasoline engines.
We only referred customers to the Bosch service center if there was an issue with the start of the subsidy process, as we didn't have any specialized tools.
Before we potentially damage something, we prefer to refer the customer to a colleague.
Since the tool is offered at a relatively low price on eBay, we will purchase it.
Thank you for your help, and wishing you a happy start to the new year.
Translated on 30-09-2026, 14:13.
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Function and components of an air conditioning system Technical Articles
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts 2.0 TDI Sealing Kit for PDE Fuel Injector Lines Diesel Engine Technology
No new posts PDE Cylinder Head Seal - Central Plug Diesel Engine Technology
No new posts Pump Not Working After Sealing? Troubleshooting On-Board Diagnostics (OBD)
No new posts ESP Switch Seal: Low Performance, Troubleshooting Diesel Engine Technology
