Wheel Bearing 35i
Burli
Post19-01-2007, 19:49    Subject: Wheel Bearing 35i Quote
I think I'm starting to develop a wheel bearing problem.
Does anyone know the wheel bearing part numbers for the rear axle (disc brakes) of a...?
Passat Variant, 35i, 1.9 TDI 90 hp, engine code 1Z, manufactured in mid-1995.
Thank you and best regards.
Burli.
Translated on 08-10-2026, 5:21.
Karma: +645 / -0   Thank you, like it!
Post25-01-2007, 9:13    Subject: Wheel Bearing 35i Quote
191 598 625 or 321 498 625A are the same bearings that have been used in almost all front-wheel-drive VW/Audi models since the early 1970s.
No new posts Wheel Bearing Failure at 70,000 km Transmission, Chassis, Body & Interior
No new posts Rear wheel bearing - URGENT!! Transmission, Chassis, Body & Interior
No new posts Faulty Wheel Bearing? Symptoms & Repair. Transmission, Chassis, Body & Interior
No new posts Wheel Bearing Failed? Diagnose & Repair. Transmission, Chassis, Body & Interior
