Windshield Washer Nozzles Adjustment - Seat Ibiza 6K
Post25-01-2007, 9:09    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Yesterday, during a heavy application of road salt on the Autobahn, we used enormous amounts of windshield washer fluid because the left-side spray nozzle was spraying too low at speeds above approximately 100 km/h.
I would like to position it higher, but I can't seem to find the right way to do it because the spray nozzle appears to be fixed in place.
According to the documentation, it should be a simple nozzle like the one found in the G4 or my Polo. However, at least on the Polo, the parts appear larger and have a ridge that likely allows for manual height adjustment.
"Does anyone know how to adjust the small Ibiza injectors (MJ 2001) and what tools are needed?"
New image with 2 perspectives.
 File size:  58.03 KB
 Viewed:  6414 times
Translated on 12-08-2026, 7:48.
bloesch
Post25-01-2007, 9:43    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Um... isn't that a control knob on the left side of the image? Or are those separate parts?
Translated on 12-08-2026, 7:50.
Post25-01-2007, 10:10    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Schraubi-Schlumpf wrote:
um... isn't that a focusing knob on the left side of the image? or are those separate parts?
Well, that slot, which looks like it's for a screwdriver, is also puzzling to me.
However, it appears that the "rotatable part" cannot adjust the spray direction, especially since it looks like a single piece connected to the rest of the housing. I have replaced the attachment with a new version.
bloesch
Post25-01-2007, 10:26    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Hmm... well, from my perspective, it looks like:
a) The entire nozzle is either pushed out or tilted away from the cap by turning the small wheel.
b.) that it's only the locking mechanism or fastening of the nozzle.
c.) It's just a fake, and the nozzle can't be adjusted... I remember something similar happening at the company once.
Have you ever tried it?
Translated on 12-08-2026, 7:52.
Maxx1278
Avatar-Maxx1278
Post25-01-2007, 10:30    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
They should actually be adjustable in the same way as those from a Golf 4 or Bora.
The part where the nozzle is located can be adjusted.
Maybe it's somehow "stuck" for you.
Best regards.
Maxx.
Translated on 12-08-2026, 7:53.
Post25-01-2007, 10:49    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Hmm... well, for me, it looks like:
a.) The entire nozzle can be detached from the housing by rotating the small wheel.
Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
Yes, just now:
The "screw" has an eccentric head with a flat section (as shown in the image above) and is a through-shaft with two heads.
When twisting, the front part of the nozzle (in the direction of travel) is supposed to be pushed downwards away from the metal sheet, which would lift the spray stream at the back. However, when twisting, very little visible change occurs on the nozzle itself.
I still messed it up somehow... we'll see if it worked on the next highway trip.
Thank you for getting this far!
Translated on 12-08-2026, 7:54.
mcgregg
Karma: +7 / -1   Thank you, like it!
Post25-01-2007, 10:52    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
The windshield washer nozzles on the Skoda Octavia are not adjustable. This hasn't bothered me so far because they work really well in almost any temperature and speed. If one of them starts spraying in the wrong direction, and cleaning it doesn't help, then it probably needs to be replaced.
The situation was exactly the opposite with the Golf II. I couldn't get it to work the way I wanted, and I never achieved a satisfactory result.
Regards, mcgregg.
Skoda Octavia II Combi TDI, 2012, 103kW/140PS MKB CFHC
Translated on 12-08-2026, 7:56.
ThomasB
Post25-01-2007, 10:54    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
That's right. However, the adjustment range is very limited, and if you turn it too far, you end up back in the starting position.
Thomas
Translated on 12-08-2026, 7:57.
Post25-01-2007, 11:09    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
ThomasB wrote:
However, the adjustment range is quite limited, and if you turn it too far, you end up back in the original position.
...or the adjustment shaft comes loose from its clip and springs out towards you...
Well, if twisting doesn't help enough, then two new nozzles with the manual adjustment flange will be purchased.
Translated on 12-08-2026, 7:58.
Herr Antje
Post26-01-2007, 9:42    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
So, as luck would have it, I'm now also having some problems with my injectors. That's why I took a closer look at them. My (Passat 3BG 2001) has this little "lever" at the outlet opening. You should be able to adjust the height with this lever, although I haven't tried it because the height seems correct. But you don't have that lever on yours.
It appears that the height is adjustable without changing the angle of the housing relative to the hood. There's an adjustment on the nozzle.
Okay, I'll add my question now. I need to clean the nozzles; they seem to be slightly clogged. The spray pattern is poor.
- What's the best way to do this? Should I use a single needle like before, or remove the entire nozzle? -- How do you remove the entire nozzle? Is the supply line to the nozzles somehow connected to a rod inside the hood, or not? How is the hose attached? Is it just pushed on?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 12-08-2026, 8:00.
Herr Antje
dieselschrauber likes this.
Post27-01-2007, 11:39    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
new findings.
Herr Antje wrote:
It appears that the height can be adjusted without changing the angle of the housing relative to the hood. An adjustment is made at the nozzle.
"Okay, I'll add my question to this thread as well. I need to clean the nozzles; they seem to be slightly clogged, and the spray pattern is poor."
- What's the best way to do this? Should I use a single needle like in the old days, or should I remove the entire nozzle?
- How do you disassemble the entire nozzle? The supply to the nozzles seems to be (I checked it out yesterday in the dark) connected to a stem from the hood, or not? How is the hose attached? Is it just pushed on?
"That's exactly right. The height is adjustable without any problems. The part number for the 3BG 2001 is 6E0 955 986. Those are the ones with heating. I took some pictures, but my cheap camera makes them too blurry to see anything clearly. I'd be interested in the price if anyone has them available."
Here's how to remove them: First, remove the plastic covers from the motor hood supports. The heating element connectors are clipped in there. Disconnect these connectors. Push the nozzle forward (in the direction of travel) and then lever it down. Then you can simply pull off the hoses. Blow them out (preferably with compressed air), and they should work again. Do not use a needle, as this will damage the spray nozzles. If they still don't work properly afterwards, replace them.
Hopefully, it will be useful to someone.
According to Petzold, the 3B still has the nozzle adjustment as shown in the picture, or Etzold doesn't even know about my nozzles (although the book is also for the 3BG, but Petzold continues to refer to the "older" nozzles). Theoretically, a conversion should therefore not cause any problems.
Aktuell:
Translated on 12-08-2026, 8:03.
bloesch
Post27-01-2007, 12:08    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
I would be interested in the price if anyone has it ready.
The nozzles were replaced with part numbers 6E0 955 986A and later with 6E0 955 986B.
Cost per item: approximately €16 each.
In addition, you now need...
- Clutch 1J0 955 875P ~ €3.10
- angle 1J0 955 665H ~ €2.40
Translated on 12-08-2026, 8:07.
Herr Antje
Post28-01-2007, 10:16    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
@Schraubi-Schlumpf
"Thank you! Were there any improvements, or is it unknown?"
Aktuell:
Translated on 12-08-2026, 8:08.
bloesch
Post28-01-2007, 10:53    Subject: Windshield Washer Nozzles Adjustment - Seat Ibiza 6K Quote
Probably... but I can't say that with certainty.
No new posts Golf 1J Washer Jets: Fix Deep Spray (99) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts G62 at the ASZ in the Seat Ibiza Diesel Engine Technology
No new posts Ibiza 6K Brake Pads: Replacement & Installation Transmission, Chassis, Body & Interior
No new posts OBD tuning for the Ibiza ASZ Diesel Engine Technology
No new posts ARL: Set Start Date for Grants. On-Board Diagnostics (OBD)
