Intercooler Leak: Is it Normal? (With Photos)
Ibi6L-ASZ
2004 Seat Ibiza
Post03-02-2007, 13:33    Subject: Intercooler Leak: Is it Normal? (With Photos) Quote
After I already had the seal from the charge air path behind the EGR replaced once due to oil mist in the engine compartment, it's now leaking again, two hose clamps further down icon_evil.gif.
I took a couple of photos. Is there a need for action here, and what can be done to properly seal the area? These clip-on hose connectors aren't really the best solution...
As you can see in the picture, a hose clamp doesn't really help either...
Here are the two images for analysis (unfortunately, the quality is poor because they were taken with a phone).
/my.php?image=spa0251eh0.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img354/4082/spa0251eh0.th.jpg" class="responsive" alt="http://img354.
/img354/4082/spa0251eh0.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
/my.php?image=spa0250vo9.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img161/6742/spa0250vo9.th.jpg" class="responsive" alt="http://img161.
/img161/6742/spa0250vo9.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
BMW 123d Coupe
Translated on 28-09-2026, 10:41.
Post03-02-2007, 13:59    Subject: Oil Leak in Intercooler: Normal or Too Much? (Image) Quote
Ibi6L-ASZ wrote:
What can be done to properly seal the connection? These clip-on hose connectors aren't really the best solution...
How did you manage to get the pipe fittings connected to the ASZ (Automatic Switching Zone)? Did you replace the hose and pipe?
My Polo has these clip things all over, and so far, they've mostly been leak-proof.
Perhaps that's because I only ever insert the connectors into the coupling when the wire bracket is in the "unlocked" position, so it can't damage the sealing lips of the rubber ring.
I don't see any urgent need for action at the moment, as long as the oil isn't dripping from the intercooler pipe multiple times a day.
Translated on 28-09-2026, 10:43.
pax
Avatar-pax
2000 Volkswagen Passat
Post03-02-2007, 17:09    Subject: Intercooler Leak: Is it Normal? (With Photos) Quote
Look at this: https://community.dieselschrauber.org/en/viewtopic.php?t=14668
Bye.
peace
Translated on 28-09-2026, 10:44.
Ibi6L-ASZ
2004 Seat Ibiza
Post03-02-2007, 19:09    Subject: Intercooler Leak: Is it Normal? (With Photos) Quote
@Ulf:
How did you manage to get the hose clamp connection onto the ASZ? Did you replace the hose and pipe?
I additionally screwed the clamp connection onto the clip connector myself, hoping to apply more pressure to the clip to make it close more tightly, but it had no significant effect; I was just too lazy to take it apart again icon_wink.gif.
My Polo has these clip things all over, and so far, they have been mostly waterproof.
Perhaps that's because I only ever slide the plugs into the coupling when the wire bracket is in the "unlocked" position, and therefore cannot damage the sealing lips of the rubber ring. . .
I've already replaced a gasket once before, so I quickly figured out how to deal with the wire clip and how to use it. icon_biggrin.gif It only took one broken gasket to learn that.
@paxViewing profile: pax:
I think I'll try replacing the seals with a new set and using the Loctite product mentioned in the link, when I get the chance.
Thank you for your help!
Sebastian.
BMW 123d Coupe
Translated on 28-09-2026, 10:46.
No new posts ATF oil leak on 74 kW TDI engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Leak MKB AKF: Oil Level Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 documentation: Oil leak at the oil cooler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Another adapter issue? Diesel Engine Technology
No new posts Residence Time: Another Question Diesel Engine Technology
No new posts Tuning Sausage: Even Better! Diesel Engine Technology
No new posts Intake Manifold Differential Error (575) - Cause Diesel Engine Technology
