Ignition Wiring Golf 3: Find It Here!
FaBu
Karma: +3 / -1   Thank you, like it!
Post04-02-2007, 13:01    Subject: Ignition Wiring Golf 3: Find It Here! Quote
Where can I find the ignition-on power source (wire 15) for the radio?
Do not want to change the ZAS.
Volkswagen Golf 3 Variant, manufactured in 1997, TDI engine.
Fabian
Bj.97 Golf Vari. AHU/CTN def.AGR;-)
100km/5L
0,216 Düsen, Kaufmann Chip,VR6 LuFiKa
Translated on 04-10-2026, 7:44.
ollli
Post04-02-2007, 23:27    Subject: SEO-Optimized Website Design: Tips & Tricks Quote
Hello.
Do you have an ashtray in the vehicle with cigarette butts? You can find the ignition plus wire by removing it.
Olli.
Translated on 04-10-2026, 7:45.
Post04-02-2007, 23:40    Subject: Ignition Wiring Golf 3: Find It Here! Quote
I thought the ignition power was already connected to the DIN radio connector.
I certainly never had to install an extra cable for my own cars.
Translated on 04-10-2026, 7:46.
FaBu
Post05-02-2007, 4:33    Subject: Ignition Wiring Golf 3: Find It Here! Quote
@ Rainer
Unfortunately, I've lost the contact information for the person at ZAS.
Now I need a new power cable (with a fuse) so that I don't have to constantly replace the ZAS (Zero-Crossing Amplifier).
Fabian
100km/5L
Herr Antje
Post05-02-2007, 7:52    Subject: Ignition Wiring Golf 3: Find It Here! Quote
"quote"
Yes, it's a G3 issue. However, the contact costs only about EUR 20. Having a constant connection is good; my 1993 model still has the original ZAS. However, if the problem is caused by your radio (drawing too much power from that line), you can still maintain the function (after installing a new ZAS) if you use that line as a control voltage for a relay.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 04-10-2026, 7:48.
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Golf3 pulls to the left (SOLVED) General Tips
No new posts Pressure Relief Valve V71: Where to Buy? Transmission, Chassis, Body & Interior
No new posts Coolant Temperature Sensor G2: Audi A3 TDI AGR Location Diesel Engine Technology
No new posts Reverse Light Wiring: Location & How-To Transmission, Chassis, Body & Interior
No new posts Relay 109: Location for AFN vehicles Diesel Engine Technology
