ABS/ESP pedestrian detection signal
duc750ss
Post13-02-2007, 18:11    Subject: ABS/ESP pedestrian detection signal Quote
Hello everyone,
First of all, thank you very much for the many helpful tips and especially the excellent articles!
I've been driving a Passat 1.9 TDI PD with a TT5 gearbox for (not that long yet), and it has 286,000 km on the clock – it's my first automatic car that I actually own.
Despite using the search function, I still have a question regarding the error code "01119 Signal for pedestrian detection" in the ABS/ESP fault memory.
What effect does this signal have, which is presumably transmitted from the automatic transmission to the ABS/ESP system? Could it explain a peculiar shifting behavior of the transmission, although this only occurs sporadically: sometimes the gears are shifted up much later, or conversely, even with slight acceleration, the transmission immediately (and unnecessarily) downshifts, even though the pressure in the same driving situation is usually sufficient to accelerate in a lower gear.
Where would be a good place to start looking for this? The Volkswagen dealership I trust (and I really mean that) is at a loss as to the cause.
Maybe someone here has a brilliant idea...
You're welcome.
duc750ss
Translated on 21-07-2026, 20:18.
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Missing Data Frame Signal: Troubleshooting Guide Diesel Engine Technology
No new posts A4 2.5 TDI G28 - No Signal Diesel Engine Technology
No new posts TDI Signal Consumption Measurement 1Z Diesel Engine Technology
