I couldn't resist, and I connected my self-made Opto Interface to my BMR (hopefully, Rainer's CAN version will be available soon
UI, that's what it was. Everything is much faster than on the MSA12 or MSA15.
I wanted to "look at big numbers" and I checked the boost pressure. It wasn't that simple, because 5 samples per second were flashing by. But I saw a 2500
. At an outside pressure of 960 mbar.
Unfortunately, my laptop can only run for 20 minutes without being plugged into a power source. Otherwise, I would have been able to record something while driving on the highway today.
I was annoyed by fields that contained values like 1024 Nm or 300 km/h.
I believe that, despite the Sportline (lower, harder, wider), I might be afraid of one of these values
Looking forward to the CAN KKL interface, which is even faster...
