How do you replace a burnt-out light bulb in a Golf 4?
eike
Post03-01-2003, 14:01    Subject: How do you replace a burnt-out light bulb in a Golf 4? Quote
Hey mechanics,
First of all, I wish you all a happy new year.
This morning, I tried to remove the front parking light bulbs on my Golf 4 TDI with air conditioning. I also found and removed the covers that need to be taken off without any problems. However, I can't seem to reach the bulbs. The car is so tightly packed that you probably need special tools or the hands of a 4-year-old to get to them icon_evil.gif.
Hat einer von Euch damit schon positive Erfahrungen gemacht und erfolgreich eine 'Birne' getauscht? icon_eek.gif
I don't want to have to drive to the workshop for every little thing, and especially not to pay for 30 minutes of labor just to replace a light bulb.
Eike.
Translated on 08-07-2026, 21:26.
Post03-01-2003, 14:40    Subject: How do you replace a burnt-out light bulb in a Golf 4? Quote
Hi Eike,
Happy New Year to you too!
It's a bit tricky to explain how the parking light bulbs are installed without a picture to refer to. Generally, the headlights are always secured with a wire clip, otherwise there are rotating or push-in sockets. If I remember correctly, the parking light bulbs in the IVer are simply pushed in. You should be able to see where they are located from the front, and then you can feel them from the back after removing the covers.
If you don't have a Security Related Access (SRA), you should be able to access everything. My TDI with air conditioning is even somewhat "accessible" in that regard. You just have to remove a cover on the driver's side, but otherwise, it's doable.
For this and the following examples: detailed illustrations are included in the "How it's done" section. Without these, I wouldn't even touch a lamp myself.
Translated on 08-07-2026, 21:29.
tdijens
Post04-01-2003, 0:06    Subject: How do you replace a burnt-out light bulb in a Golf 4? Quote
ich habe bei meinem Golf IV TDI mit Klima auch schon beide Standlichtlampen tauschen dĂźrfen. Es war ein Akt !!! So:
Deckel abnehmen, von vorne durchs Scheinwerferglas schauen, wo sich die Lampe befindet und dann mit schlanken Händen die Fassung inkl. Lämpchen erfassen und aus dem Gehäuse herausziehen. Anschl. ziehst Du das Lämpchen aus der Fassung, ist alles nur gesteckt, soweit ich mich erinnere. Erschwerend kommt bei der Prozedur dazu, daß das Kabel zur Fassung am Scheinwerfergehäuse mit einem Kabelbinder befestigt ist. Es ist also wirklich die letzte Fummelarbeit! Aber es geht, wenn die Hände/Finger nicht zu dick sind. Gott sei Dank halten die Standleuchten wesentlich länger als die Abblendleuchten. VieSuccess!
Best regards, Jens.
Translated on 08-07-2026, 21:32.
illuminat-23
Post05-01-2003, 11:09    Subject: How do you replace a burnt-out light bulb in a Golf 4? Quote
Okay, I always change my headlights by quickly removing the entire headlight assembly; in my opinion, that's the fastest way, and besides, I don't get my hands scratched doing it. icon_idea.gif
eike
Post06-01-2003, 9:07    Subject: How do you replace a burnt-out light bulb in a Golf 4? Quote
welche Schrauben lĂśst Du dafĂźr? RDo the superiors decide?
It looks like, in my case, you would also have to remove the front grille to do that.
Eike.
Translated on 08-07-2026, 21:33.
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front Wheel Bearing Noise (Golf 4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Defective Diesel Pump: What to Do Now? Diesel Engine Technology
No new posts Damaged VTG Tank Container Diesel Engine Technology
No new posts [Poll] Faulty Glow Plug: VW 2.5 TDI BDG Issues Diesel Engine Technology
No new posts ESP Failure: Common Causes and Solutions Diesel Engine Technology
