Window Repair Malfunction After GPS Installation
poppel
Karma: +1 / -2   Thank you, like it!
Post02-03-2007, 22:12    Subject: Window Repair Malfunction After GPS Installation Quote
Hello, I installed the RNS2 navigation system in my T5 today.
Everything went perfectly.
I just had one window open before disconnecting the battery.
Now, the automatic up-and-down function for the windows is no longer working.
I once had a similar issue with my Golf IV. All I had to do was roll up the window, disconnect the battery, wait a moment, and then reconnect it, and everything was fine.
It doesn't work like that with the T5 Multivan.
I need help.
Poplar.
Translated on 27-10-2026, 15:33.
BM
Avatar-BM
Post02-03-2007, 23:44    Subject: Window Repair Malfunction After GPS Installation Quote
Perhaps this will help:
Run each window up and down to its limit once, and hold each corresponding switch in place for approximately 1 second after it reaches the limit, allowing the window motor to find its end position (pinch protection).
3B5 AJM
Translated on 27-10-2026, 15:34.
poppel
Post03-03-2007, 0:22    Subject: Solution: Find the best solutions now! Quote
The power windows need to be reprogrammed.
Hold the driver's door key in the "lock" position until all windows are fully closed.
Then, I'll keep the opening in the "open" position until the windows are fully open.
It resets the power windows.
Thank you, ab Schroeder, from the T5 Board Team.
It should also be included in the user manual, which I probably overlooked.
Poplar.
Translated on 27-10-2026, 15:35.
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
No new posts Window Repair: Audi A4 (1999) - Fix Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 5, Problems with windshield washer/water system Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat B5: Driver Window Not Working (1999) Transmission, Chassis, Body & Interior
No new posts Audi B5, 1999 - Retrofitting from small navigation system... Transmission, Chassis, Body & Interior
No new posts GRA Installation Error: Troubleshooting Guide Diesel Engine Technology
No new posts ACC Coding for A4 B8 FL After AHK Installation On-Board Diagnostics (OBD)
