Bolzer Blaumann
30-03-2007, 20:44 Subject: ZV Pump Error MWB 007 |
Hi.
I want to retrofit the original FFB (Fuel Filler Pass) system to my Audi A4 B5, manufactured in 2000. I purchased and installed the pump (part number 8D0 862 257 B) and the antenna. Unfortunately, I can't pair the remote keys. I also can't access control module 7, neither with the old pump nor the new one. Coding functions work, and the pump itself is working. What could be the problem?
I hope you can help me.
Best regards, Bolzer.
Translated on 31-08-2026, 10:52.
30-03-2007, 20:45 Subject: ZV Pump Error MWB 007 |
Are you sure the pump supports FFB (Force Feedback)?
Bolzer Blaumann
30-03-2007, 20:50 Subject: ZV Pump Error MWB 007 |
Hi.
It's being read as a radio signal. I think it's a D12.
Translated on 31-08-2026, 10:53.
30-03-2007, 20:55 Subject: ZV Pump Error MWB 007 |
VAG-COM > Selection > 35 - Central Locking > Fault Memory - 02 > Copy/Save Error
...and please add that here.
Bolzer Blaumann
30-03-2007, 21:07 Subject: ZV Pump Error MWB 007 |
Hello Sebastian,
Here is the log.
Friday, March 30, 2007, 10:04:30 PM
VAG-COM Version: RKS 607.3-UD
Control unit part number: 8D0 862 257 B.
Component and/or Version: ZV Pump, Wireless D12.
Software Coding: 14913
Workshop code: WSC 44644.
No errors found.
Translated on 31-08-2026, 10:54.
30-03-2007, 22:04 Subject: ZV Pump Error MWB 007 |
Okay, the problem is that this control unit simply doesn't have MWB 007. So, the question is, how are you getting that information?
http://www.ross-tech.com/vag-com/cars/vw-remote-matching.html
Here's an example: MWB 003 - and that applies to your case.
Translated on 31-08-2026, 10:55.
Bolzer Blaumann
30-03-2007, 22:32 Subject: ZV Pump Error MWB 007 |
Hello.
I followed the instructions that the friendly person gave me.
But my guess is that, since the pump is "older," the instructions are for the newer model.
Okay, I'll try that and get back to you.
Sure, you're welcome.
Translated on 31-08-2026, 10:56.
30-03-2007, 23:03 Subject: ZV Pump Error MWB 007 |
Translated on 31-08-2026, 10:57.
