brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
03-03-2007, 16:44 Subject: Webasto T90 Receiver Wiring Diagram |
Hello!
Could someone possibly post the pinout for the Webasto Telestart receiver T90? I'm specifically interested in the 6-pin connector.
"What would be helpful for me is the pin number, wire color, and of course, the signal of the connection. For example, +, -, CAN, and so on..."
Sure, I can also do it via private message.
"Thank you!!"
Dirk. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 22-09-2026, 23:57.
10-04-2007, 11:37 Subject: Webasto T90 Receiver Wiring Diagram |
Okay, so... the pin configuration seems to be clarified, and the communication between the receiver and transmitter appears to be working fine. Unfortunately, I'm still missing a manual with the basic functions, such as setting the heating time and ventilation modes. As I said, this is for the T90, and unfortunately, there's nothing to be found on the Webasto homepage.
"Thank you!"
Translated on 22-09-2026, 23:58.
