Opel brake pad wear indicator reset
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post10-04-2007, 14:57    Subject: Opel brake pad wear indicator reset Quote
Hi, is it possible to reset the brake pad wear indicator on an Opel Zafira, manufactured around 2002, without using OBD software?
If so, how?
Or do I need to take it to the workshop?
The indicator light is still on after the pads were replaced. I assume it's not supposed to go off automatically, or could something have been done incorrectly during the replacement that's preventing it from turning off?
Thank you, Sven.
Passat Variant Highline 2,0 TDI 103KW
scrdel
Post11-04-2007, 20:23    Subject: Opel brake pad wear indicator reset Quote
... then I have to answer myself icon_smile.gif.
The wear indicator, or the contact points on the brake pads, are separate parts on Opel vehicles and are not integrated into the pad itself, unlike my VW.
So, my acquaintance now has to order and replace the wear contacts, and then it should be fine.
http://www.langzeittest.de/opel-zafira/technik/bremsbelaege-vorne.php
Sven.
No new posts Doku Audi A8, Bremsbelagverschleißanzeige leuchtet dauernd Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Sharan Bremsbelagverschleißanzeige On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Resetting the service interval on an Audi A3 8P On-Board Diagnostics (OBD)
No new posts Resetting DPF values in the MSG using RossTech VCDS Diesel Engine Technology
No new posts Passat B5: Service Reset Instructions On-Board Diagnostics (OBD)
