Check temperature flap or servo motor - Audi Coupe
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
myfisch
Post10-04-2007, 21:58    Subject: Check temperature flap or servo motor - Audi Coupe Quote
Today, I briefly worked on a late 90s coupe where the temperature control system isn't functioning correctly. Specifically, the car is heating up regardless of the temperature setting. Out of desperation, since Audi claimed that a diagnosis and actuator test were not possible, I swapped the control unit with one from an identical vehicle, as this was supposedly a known issue.
No change!
'Definitely, after being exposed, the temperature control flap doesn't move. How can I check the control signal? Unfortunately, I have the somewhat uninformative manual, but not yet a wiring diagram.' Has anyone else experienced similar problems and can offer assistance?
Thank you, Tom.
olli
Karma: +46 / -0   Thank you, like it!
Post11-04-2007, 8:44    Subject: Check temperature flap or servo motor - Audi Coupe Quote
If it's a Klima system with a dual-display, it should definitely have a fault memory and a self-diagnostic function.
The climate control actuators are a recurring problem across all Audi model lines. The issue is that carbon dust, which forms on the commutator due to wear, eventually causes short circuits. This prevents the current from flowing through the motor windings, instead diverting it through the commutator itself. A solution can be either a completely new servo motor or disassembly, cleaning, and possibly replacement of the carbon brushes (which are compatible with those used in Märklin model train locomotives).
You can find the instructions on how to switch the climate control system into diagnostic mode, as well as the meaning of each channel, at http://www.meckisforum.de. If I remember correctly, it should also be possible to control the individual motors directly.
Best regards from Berlin.
Olli.
A6 CANA/JME /
Ex-A6 AEL
wolfi_b
Post11-04-2007, 11:04    Subject: Check temperature flap or servo motor - Audi Coupe Quote
olli wrote:
If I remember correctly, it is also possible to specifically target the individual motors.
Yes, that's correct. The temperature control valve can be manually adjusted using the "+" and "-" buttons of the fan control system in channel 10 (setpoint temperature control valve).
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
myfisch
Post16-04-2007, 19:41    Subject: Check temperature flap or servo motor - Audi Coupe Quote
THANK YOU.
Following update: After discussion, I was able to obtain a self-diagnosis and a functional test from the technician. Result: The pressure relief valve and temperature control valve are occasionally malfunctioning.
I opened the engines and now they're working again.
Best, Tom (but still installing new ones).
wolfi_b
Post17-04-2007, 8:03    Subject: Check temperature flap or servo motor - Audi Coupe Quote
myfisch wrote:
Pressure relief valve
Did you manage to do it without removing the dashboard and the entire ventilation system?
1993 Audi 80 B4 1Z
No new posts Skoda Superb Estate (Wagon), 2012, Tailgate Actuator Defe... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts Temperature Blend Door Actuator Transmission, Chassis, Body & Interior
No new posts Passat 3B temperature flap control motor On-Board Diagnostics (OBD)
No new posts Temperature flap actuator (V158) or G220 Transmission, Chassis, Body & Interior
No new posts Temperature flap servo motor - no target value? (V159, ri... Transmission, Chassis, Body & Interior
