I have also implemented the technical article, but I still have questions about the approach and a suggestion for expanding the article.
I have paused the service on channel 2.
After that, follow the VAG-COM suggestion (an explanation window will open).
Channel 42, which is not mentioned in the article or listed in the table (!).
Here, I can enter the minimum kilometer distance to the next service interval in increments of 1,000 km: for example, 15,000 km.
Channel 43: Maximum distance, e.g., 50,000 km.
Channel 44: Maximum duration: 730 days.
Channel 45: Oil quality: 4 = Low.
after that, I could (according to VAG-COM) go into...
Channel 40, "distance from inspection," in increments of 100 km.
Enter the "distance from inspection" in days in field 41.
Due to a lack of knowledge, I didn't change anything there.
What do these values mean? Do I need to enter anything if I reset the service settings from x km or y days after the actual service (hence from, and not }until/to})? Or can I precisely define when the next service should be, i.e., specify a fixed interval?
You're welcome, haithamina. 3G5, 110 kW, DFGA, TGV, Variant HL 2018-
Translated on 03-09-2026, 4:05.
