Audi A6: AFN/WFS Problems - Common Issues & Fixes
Post07-06-2007, 14:49    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
Strange: AFN 01262 and WFS issues with Audi A6, 4B.
Hello diesel enthusiasts,
I am experiencing the following problems with my Audi A6 AFN, manufactured in 1998:
Before my vacation trip, the car wasn't performing well; it was running like it didn't have a turbo.
The problem was a torn vacuum hose on the turbocharger and a damaged cable to the N75 valve (magnetic valve for boost pressure control, turbocharger). The hose and cable have been repaired. During a test drive, the Audi ran perfectly again.
"As we were about to leave, the car wouldn't start. The starter motor wasn't engaging. I suspected a problem with the immobilizer (wiring connection, sensor, etc.). I tapped lightly on the ignition switch several times and adjusted the steering wheel up and down. > The A6 started. With a slightly uneasy feeling, I then drove 850 km without any problems. During the vacation, the car would consistently start on the second or third attempt and ran perfectly. > This obviously can't continue like this. Today I'm back home. In total, about 2000 km were driven."
"I just read the error memory and surprisingly only found error code 01262: 'Solenoid valve for boost pressure control N75, 31-10 open or short to ground - intermittent.' So, it's that solenoid valve. However, the car is running perfectly fine. This error message reappears immediately after clearing it and restarting the engine (idling only)! I checked the valve according to the workshop manual: The resistance between the two contacts is 16 ohms, which is within specification!"
The repaired (soldered) connection is also working properly, unless there's a really bad "intermittent fault" that I didn't notice while testing.
Here's the first question: What is the resistance (with the ignition off) measured between terminal 1 and terminal 2 on the cable?
Surprisingly, I don't find any error codes related to the reading coil, key, WFS (signal too weak), or anything similar in the fault memory.
Actually, the two errors (starting problem and solenoid valve issue) probably aren't related to each other... or are they?
Could this be the much-discussed relief relay (which would likely be number 100 or 219 in my case)?
How can I check this?
0928-761
Translated on 21-08-2026, 0:55.
Rudi
Post07-06-2007, 15:03    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
Hi.
The WFS is not your problem!
If it starts, the engine kicks on and then turns off again after about one second.
You seem to be encountering a more fundamental problem in the area of power supply/connection for the MSTG (Multi-Sensor Test Gauge).
to have.
A faulty 109 often leads to the funniest error messages – although, more commonly, it results in different icon_confused.gif.
The relays in the A6 are located near the steering column, which could cause slight vibrations.
Can the ignition switch also be transferred there?
Then you should definitely thoroughly examine the relay (or replace it immediately, or resolder everything).
Rudi
Translated on 21-08-2026, 1:00.
Post08-06-2007, 11:23    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
I have now checked various relays and wiring, and everything seems to be fine... icon_smile.gif
Could it be that the magnetic switch on the starter motor is sticking - occasionally? icon_cry.gif
Because: after approximately 3 seconds, only the battery indicator in the instrument cluster lights up, so everything is as it should be. icon_smile.gif
Has anyone here ever replaced this part before?
What problems occurred back then?
The error code "Magnetic valve, boost pressure limiter" would not be related to the occasional starting problems.
Best regards, 0928-761.
Translated on 21-08-2026, 1:02.
Post08-06-2007, 11:30    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
Yes, that could be it. However, it might also be due to the ignition switch contact set, which sometimes fails to send power to the starter motor. Or there could be a loose connection somewhere between the ignition switch and the starter motor.
Is your problem only that the starter motor occasionally stops working, or does it also sometimes crank normally (as it should), without the engine starting?
The read error code: "Magnetic valve, boost pressure limitation," would then have nothing to do with the - occasional - starting problems.
Okay.
Translated on 21-08-2026, 1:04.
Post08-06-2007, 12:15    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
No, the starter motor never just whirs. When it starts, it always does so immediately with the ignition key – or, alternatively, it makes absolutely no sound at all icon_sad.gif.
Translated on 21-08-2026, 1:05.
Post08-06-2007, 12:43    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
0928-761 wrote:
No, the starter motor never just whirs. When it starts, it always does so immediately with the ignition key - or it doesn't make a sound at all. icon_sad.gif
Then the problem lies somewhere between the ignition switch and the starter motor (unless all the lights go out when it doesn't start, in which case it's likely the battery or the wiring around it).
Small consolation: because of this defect, it will never unexpectedly run out on you, and if necessary, it can also be pushed/towed/rolled icon_wink.gif.
Translated on 21-08-2026, 1:06.
Post08-06-2007, 13:17    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
Thanks, Ulf! That sounds logical and fits with the observed problem(s).
I will now try to narrow down the error to one of the two components or their connections.
If anyone has a practical tip to share, please feel free to do so.
The problem is that it's very difficult for me to access the starter motor itself for measuring purposes... icon_sad.gif
Otherwise, I'm going to have to struggle through the wiring diagrams now.
Mfg 0928-761
Translated on 21-08-2026, 1:08.
Post08-06-2007, 20:10    Subject: Audi A6: AFN/WFS Problems - Common Issues & Fixes Quote
This afternoon, I replaced the ignition switch (24 euros) because everything was already disconnected for testing. On the Audi A6 (C5, 4B), this is only attached to the ignition lock with two set screws.
A laborious process of removing a sleeve, like in golf, was not required. icon_lol.gif
The problem with the occasional non-starting issue persists. icon_sad.gif icon_sad.gif
Okay, so I'm going to focus on the starter now.
Translated on 21-08-2026, 1:09.
Post16-06-2007, 14:24    Subject: Valeo Starter Motor: Replacement & Repair Guide Quote
Okay, here's the final part of the project:
It was the magnetic switch (available separately for €39 including shipping on eBay!) of the starter motor! However, when ordering, you need to know the manufacturer (in my case, it was a "Valeo") and the OEM number "068911024E" of the starter motor. You could barely read it from above using a flashlight.
To the admin:
The topic doesn't fit into this subforum anymore. > However, I couldn't have known that beforehand.
Best regards from 0928-761.
P.S.: The error code "Boost Pressure Control N75" was caused by a poor pin connection... However, the car always ran perfectly fine. It's usually those small things that cause all the trouble...
Translated on 21-08-2026, 1:11.
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A5 2.7 TDI Multitronic: Common Problems Transmission, Chassis, Body & Interior
No new posts Tiptronic Problems Audi A4 B5 2.5 TDI Transmission, Chassis, Body & Interior
No new posts Audi 4F Multimedia Control Unit Problems On-Board Diagnostics (OBD)
No new posts Boost pressure problems on Audi A4 B5 1.9 TDi AFN 1996 Diesel Engine Technology
