Graphics Card Not Working? Troubleshooting Guide
gunther
Post03-07-2007, 20:07    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
Today, I installed a GRA (Gearbox Rear Axle) in my Passat (year 2000; engine code: AKN). It was an original retrofit kit from VW. I installed and connected everything as described in the included manual. It was unlocked using code 11463. However, this thing just won't work. According to the manual (code GOOOSG), the control unit shows that it is unlocked, and according to measurement block 6, all functions are being switched correctly on the switch, with "0" and "1" as they should be, including the clutch and brake. So, I hope the switch is okay and properly connected. I have tried unlocking it multiple times because I read in the forum that it sometimes doesn't work the first time. Nothing is working! No warning lights are coming on, and it's not functioning. Now I'm completely at a loss and hope you can help me.
Translated on 26-10-2026, 18:31.
Schlack
Post03-07-2007, 22:16    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
Okay, I wouldn't look for the error in the control unit if the corresponding diagnostic trouble code (DTC) is correct. Control units are digital; it's either a 0 or a 1, it either works or it doesn't.
I once installed something similar in a Passat, and I found it incredibly fiddly to insert and locate the individual pins in the water tank.
Therefore, the question is: are you sure you haven't mixed anything up, made a mistake in your calculations, been misled, or done something wrong?
If it's different from how I remember it being installed, like for example with the AFN fuel pump in a Golf, where it just snaps together, then I don't have any other ideas.
Greetings.
Jubi G3 GTI TDI
Spritmonitor.de
Translated on 26-10-2026, 18:33.
gunther
Post03-07-2007, 22:48    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
Routing the wiring harness was a real pain, and I double-checked everything after I plugged the pins into the connectors, keeping in mind that correcting any mistakes would be a huge hassle. I'm pretty sure I didn't mix anything up.
Translated on 26-10-2026, 18:34.
gunther
Post04-07-2007, 17:43    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
Okay, so...
It works now, icon_biggrin.gif.
Habe sie noch mal deaktiviert und anschließend wieder aktiviert und dann ging es plötzlich. Kontrollleuchte ist allerdings Fehlanzeige, die leuchtet zu keinem Zeitpunkt. Was ich so mitgekriegt habe soll das wohl normal sein und läßt sich auch nicht beheben. OdeSure.
Greetings.
mullemaus
Post04-07-2007, 19:07    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
With a different engine control unit, and possibly a more recent software version for the control unit. icon_wink.gif Cumbersome, expensive, nonsense. icon_lol.gif icon_wink.gif
Translated on 26-10-2026, 18:35.
Post05-07-2007, 14:01    Subject: Graphics Card Not Working? Troubleshooting Guide Quote
The light fixture is pointless anyway.
It lights up when the GRA *can* be activated, not when it *is* activated.
What kind of brake lights are those that light up when you *can* brake?
With the 3C, VW enthusiasts noticed that it can be interesting to see if the GRA (presumably a sensor or system) is actually working, as it indicates its status. The Golf 3, on the other hand, doesn't show anything at all, only regulates – no indication.
Greetings.
m
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS does not recognize Skoda Octavia; Gateway not supported On-Board Diagnostics (OBD)
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
No new posts Car won't start, lights not working Diesel Engine Technology
No new posts Glow Plug Not Turning Off? Engine Won't Start. Diesel Engine Technology
