Bolzer Blaumann
18-07-2007, 5:19 Subject: G4 Driveshaft: Replacement & Parts |
Hi.
"A long time ago, I installed the 6-speed gearbox from the ARL engine into my G4 ASV, along with the corresponding drive shafts. Now, the right drive shaft is about to fail. Do I absolutely need to use the drive shaft from the 150 HP ARL engine again, or can I also use the one from the 130 HP ASZ engine? Are there any physical differences (length, thickness, etc.)?"
Best regards, Bolzer.
Translated on 01-10-2026, 1:29.
DariusPolo Guest
18-07-2007, 5:40 Subject: G4 Driveshaft: Replacement & Parts |
The engine from the ASZ (130 hp) is very similar to the one from the ARL (150 hp), and they are compatible with each other.
Darius.
Translated on 01-10-2026, 1:30.
Bolzer Blaumann
18-07-2007, 6:09 Subject: G4 Driveshaft: Replacement & Parts |
Hi.
Thank you for the quick response. Then I can order the wig right away.
Bolzer.
Translated on 01-10-2026, 1:31.
