WFS Setup: How to Configure and Use
Post25-08-2007, 1:40    Subject: WFS Setup: How to Configure and Use Quote
WFS (Water Flow Sensor) for a Seat Toledo 1.9 TDI, engine code: AHF, manufactured in August 1999.
Pairing is not working! The WFS is integrated into the control panel.
I proceeded as follows: 17 combination instrument - 11. The login with the number 0453 is not working! Am I perhaps doing something wrong?
The transponder identification number is SEZZZ0X0095975. The login should be 0453, but I'm not sure if that's the correct login. *thinking*
I obtained the key through the Seat dealer using the vehicle's chassis number, because the two keys were lost icon_eek.gif.
Friendly mechanic wants €60 to help me get started. However, I would first have to load the entire car onto a trailer and transport it, which seems too complicated for me.
Unfortunately, I can't find any instructions on how to pair the WFS (Wireless Front System) with a Seat Toledo.
Translated on 02-09-2026, 6:18.
n8ive
Karma: +0 / -1   Thank you, like it!
Post25-08-2007, 8:01    Subject: WFS Setup: How to Configure and Use Quote
Good morning, where did you get the PIN from? As far as I know, these are all connected online, and they no longer have access to the PIN themselves. This means a visit there is unavoidable. Also, the PIN is only valid for one day. Best regards.
Translated on 02-09-2026, 6:20.
Back to top Profile PM Email
Post25-08-2007, 9:45    Subject: WFS Setup: How to Configure and Use Quote
This is a WFS of the second generation, so why should PIN 1 be valid? I can understand that with the newest WFS! Login is not the same as PIN.
mullemaus
Post25-08-2007, 12:00    Subject: WFS Setup: How to Configure and Use Quote
Good morning, where did you get the PIN? As far as I know, THEY are online and no longer have access to the PIN themselves. This means a visit THERE is unavoidable. Also, the PIN is only valid for one day.
There's something wrong with what you're saying. The fax retrieval for the login code is still possible. It comes as a 7-digit code and is entered with the WSC and importer number, or it can be converted to a 4-digit code. The 7-digit code is actually only valid on the day it is requested; with VAG-Com, it can always be retrieved by specifying the date. icon_wink.gif
@ T3 Surfer, what does the dashboard say about the WFS (Web Firewall Service) when logging in? Are there any lockout times?
Translated on 02-09-2026, 6:21.
Post25-08-2007, 12:24    Subject: WFS Setup: How to Configure and Use Quote
Mullemaus:
"Glow plug" and "key symbol" are blinking! When entering the login with a VAG tester, it returns an error code 1551. I can only access it again by turning the ignition on and off, but when I try again, it goes back to the beginning. icon_cry.gif The request for the transponder code identification from Seat is 4 digits! } The error on the MSTG is "control unit locked," and the WFS shows "incorrect key."
Translated on 02-09-2026, 6:23.
mullemaus
Post25-08-2007, 17:07    Subject: WFS Setup: How to Configure and Use Quote
Then the login won't work. icon_wink.gif Please send me the data or a scan of the fax via private message or email. Where are you coming from?
Translated on 02-09-2026, 6:24.
Post25-08-2007, 17:50    Subject: WFS Setup: How to Configure and Use Quote
Hey Mulle, you've got mail icon_smile.gif.
Post27-08-2007, 17:34    Subject: WFS Setup: How to Configure and Use Quote
It's resolved; my mistake was using the wrong login credentials, and I didn't realize that a "0" had to be included before the login number.
Many thanks to Mullemaus icon_wink.gif icon_wink.gif.
No new posts Pairing VW radio keys Troubleshooting & Guides
No new posts Audi Key Fob Pairing: How To Guide Troubleshooting & Guides
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW New Beetle: Program Remote Key Fob On-Board Diagnostics (OBD)
No new posts PDC Golf 5: Troubleshooting Parking Sensor Calibration Electrical Systems, Vehicle Electronics, Multimedia
No new posts Throttle learning not possible Gasoline Engine Technology
No new posts Audi A6 4B - Instrument Cluster Replacement - Coding to E... On-Board Diagnostics (OBD)
