donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
19-03-2007, 8:38 Subject: Thumping at the clutch pedal |
Hello everyone!
I recently noticed that my clutch pedal feels noticeably pulsating when I press it lightly (the clutch is not disengaged and is still far from the engagement point). Normally, people don't do this, but maybe you could try it at your place.
I find it very strange, because I can only explain the pulsating motion by a mistake in the swing arm of the bicycle. How do you see it?
Greetings
Alex AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
19-03-2007, 10:17 Subject: Thumping at the clutch pedal |
It also works for mine, I've gotten used to it now (238,000 km) ...
Hello, Rainer
Profile PM WWW Garage |
D. Kurz Guest
19-03-2007, 12:12 Subject: Thumping at the clutch pedal |
Hello!
My Golf was still okay at a speed of 183 km/h, but the problem started around 200 km/h in my Passat. As the driver, I suspect the clutch more. As long as it doesn't completely break down, I'll continue driving. With TDI, you can drive a manual transmission for a long time with just a little bit of feeling in your feet.
Greetings,
Dominique
19-03-2007, 12:20 Subject: Thumping at the clutch pedal |
My stomach is already full, so I don't want any more...
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
19-03-2007, 12:32 Subject: Thumping at the clutch pedal |
[quote="D. Short: "Hello!"
Greetings,
Dominique[/quote]
There might also be other reasons, as the lever to the release lever is very short, and even the slightest vibration from the suspension is amplified through the clutch actuation. If we roughly estimate that with an axial play of 3/100mm, this movement roughly ten times the size of my thumb on the pedal, then you should definitely notice it.
But, of course, this also includes the Fakto brake lever.
A ZMS would also be a worthwhile addition, especially when considering the Valeo and LUK parts, and seeing that the vibration damper is only moved by striking the spring ends.  Peugeot 307 (T5)1450kg Speck, RHS, MJ2002, 138g CO2 inkl. Korken im Auspuff und goldene Möhre 2006, MAF+50% mit passender Dieselmasse. nunmehr 370000km
Hutfahrer Schrauber
Joined: 10/22/2005 Posts: 7828 Karma: +1100 / -0 Location: BAR
19-03-2007, 12:38 Subject: Thumping at the clutch pedal |
...this has been on my Suzuki Ignis for approximately 45,000 km. Now it's at around 76,000 km. The mechanic just said: "Keep driving until it stops!" - especially since it only seems to happen when the car is cold. Automobile Zeitzeugen: |SUZUKI Swift Sport (2008)| |Smart 450 (2002)| |Honda CB 125 F (2018)|
makrospex Blaumann
19-03-2007, 16:26 Subject: Thumping at the clutch pedal |
The pulsing is also happening to mine (Passat, AFN, 180,000km).
In the previous model (same values, but an older model), it was gone after a comprehensive clutch repair. "However, almost everything was replaced, including the clutch lever and the flywheel."
I've been driving the newer Passat for 4 months now, and the symptoms haven't gotten worse. Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
19-03-2007, 16:29 Subject: Thumping at the clutch pedal |
and if it's the plate-spring of the pressure plate? So, if the "arms" protrude differently towards the release lever? Then, with each U, the gear is put into a whirling motion that extends all the way to the pedal (but only if it's not too tight).
derteileklaus Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
makrospex Blaumann
28-08-2007, 13:56 Subject: Thumping at the clutch pedal |
I had to replace the clutch on my new Passat (191,000 km, first clutch, and used for towing) after all.
The vibrations are gone, cause:
Pilot storage and ZMS are defective.
Greetings,
macro Opel Vivaro Kombi, 2.0 CDTI 110kW BlueHDI (MKB: AH01), BJ 2020
