A6 4F: Install Horn DWA System
Post06-09-2007, 7:41    Subject: A6 4F: Install Horn DWA System Quote
Hi.
Yesterday, I wanted to make an Audi A6 4F honk its horn so that the owner would know when the car was locked or unlocked.
The Comfort STG was copied 133 times, so:
1 + 4 + 128
He didn't eat the 2048, probably because the DWA (16) wasn't encoded.
He does!
Should then.
Is this the solution: 1 + 4 + 16 + 128 + 2048?
From http://de.openobd.org/audi/a6_4f.htm#46
Code:
+000001 - Standard (immer aktiv)
+000002 - 10 Tamperalarme (GB/Irland, PR-B09)
+000004 - Schließzylinder entriegelt ZV elektrisch (PR-7AA/8AU)
+000008 - Selektive Zentralverriegelung (SZV, PR-4K2/4K7/4K8)
+000016 - Diebstahlwarnanlage (PR-7AN/7AL)
+000032 - Neigungssensor (PR-7AN/7AL)
+000064 - Innenraumsensor (PR-7AL)
+000128 - Komfortfunktion über FFB (nicht PR-B29/B30/B34/B35)
+000256 - Rechtslenker (PR-L0R)
+000512 - Avant (Heckscheibenbrucherkennung, PR-K8D)
+001024 - Heckrollo (PR-3Y2/3Y5)
+002048 - Quittierung DWA hupen (PR-A8U)
+004096 - SAE-Rückleuchten (USA, PR-A8U)
+008192 - Lichtpaket (PR-QQ1)
+016384 - keine SAFE-Funktion (PR-A8U)
+065536 - Diebstahlwarnanlage-Verzögerungszeit (0 Sekunden)
+131072 - Ausstattung Highline (Heckleuchten LED)
+262144 - Schiebedach (PR-3FE/3FR)
+524288 - Multifunktionsgerät (PR-F0X/F4E/F4F/F4G/F4J/F4Q/F4X/F4Z/F5F)
Translated on 19-09-2026, 2:07.
Maxx1278
Avatar-Maxx1278
Post06-09-2007, 10:10    Subject: Audi A6 4F: Install Horn with DWA function Quote
dieselmartin wrote:
Should it then...
1 + 4 + 16 + 128 + 2048 could that be the solution?
I see it that way too.
It might also be worth investigating whether he uses the IRUE and NGS systems.
Sure, Maxx.
Translated on 19-09-2026, 2:09.
Ross-Tech-Support
Post06-09-2007, 11:47    Subject: Audi A6 4F: Install Horn with DWA function Quote
Maxx1278 wrote:
It might also be worth investigating whether he has installed the IRUE and NGS systems.
IRÜ and NGS are not that relevant; the vehicle's immobilizer system (DWA) generally functions without them, relying on the door contacts and immobilizer. However, the real question is: is the DWA system, including the DWA siren, actually installed?
Translated on 19-09-2026, 2:10.
Maxx1278
Avatar-Maxx1278
Post06-09-2007, 12:02    Subject: A6 4F: Install Horn DWA System Quote
You're right about that, Sebastian.
My comment was only intended as additional information.
It is clear that the DWA (water treatment plant) should also function without the two sensors.
SG, Maxx.
Translated on 19-09-2026, 2:11.
"Do you have any tips on how to ensure proper installation of plumbing fixtures?"
Ross-Tech-Support
Post06-09-2007, 12:05    Subject: A6 4F: Install Horn DWA System Quote
Maxx1278
Avatar-Maxx1278
Post06-09-2007, 12:06    Subject: A6 4F: Install Horn DWA System Quote
I would do the following:
1.) Encode your solution.
2.) Open the hood.
3.) All doors and the tailgate will close.
4.) Lock the vehicle.
5.) Use a screwdriver to press the microswitches located on the hood lock mechanism.
6.) After a few seconds, release the button again.
If a water leak detection system (DWA) is installed, the vehicle should sound a horn or buzzer.
SG, Maxx.
Translated on 19-09-2026, 2:12.
No new posts Central Locking: How to Make Your Horn Work Transmission, Chassis, Body & Interior
No new posts Fuel additives: Should you try them? Diesel Engine Technology
No new posts A new and more powerful TDI is needed Diesel Engine Technology
No new posts Finally, it works! (Or: It's working!) Diesel Engine Technology
