Disable 4Motion control module in the CAN gateway
michiglaser
2007 Audi A4 Avant
Post11-09-2007, 16:44    Subject: Disable 4Motion control module in the CAN gateway Quote
Hello!
I constantly have the error code "01324 Control unit for all-wheel drive - J492 - no communication" in the error memory, even though I don't have all-wheel drive.
How can I make the CAN gateway understand that the car does not have 4Motion?
(2002 Volkswagen Golf 4, ASZ engine)
Sure, here's the translation:
"Thx."
Michael.
T5 California (CFCA) 4Motion
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 08-07-2026, 8:37.
Ross-Tech-Support
Post11-09-2007, 16:59    Subject: Disable 4Motion control module in the CAN gateway Quote
Re-code the CAN gateway with the current coding (usually 00006). This will initiate an update of the parts list, and the all-wheel drive control unit (J492) should be removed from the parts list, which should then resolve the error.
Translated on 08-07-2026, 8:38.
Jochen_145
Post11-09-2007, 17:00    Subject: Disable 4Motion control module in the CAN gateway Quote
Hello.
In which department does this error occur?
I would have expected to find it in the MSG (Main System Gateway) and not in the KI (Key Interface), because, to my knowledge, you can only change the all-wheel drive coding in the MSG.
Take a look at the MSG encoding.
Sebastian should know much more about this, or one of the 4Motion drivers.
Best regards, Jochen.
[edit]
Translated on 08-07-2026, 8:39.
michiglaser
2007 Audi A4 Avant
Post11-09-2007, 18:09    Subject: Disable 4Motion control module in the CAN gateway Quote
Sebastian@OpenOBD wrote:
CAN-Gateway mit der aktuellen Codierung (i.d.R. 00006) neu codieren, dadurch wird eine Aktualisierung der Verbauliste initiiert und das Steuergerät für Allradantrieb (J492) sollte aus der Verbauliste herausfallen was den Fehler dann egalisiert.
Yeah, thank you icon_smile.gif.
That's how it went.
Too bad, I would have really liked to have 4Motion icon_wink.gif.
A4 B8 Avant (CDUC)
G4 (ASZ), T4 (AXG)
Translated on 08-07-2026, 8:40.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post11-09-2007, 20:55    Subject: Disable 4Motion control module in the CAN gateway Quote
Hi.
Sorry, I missed that, it's already been sorted out.
"Could it be that your engine control unit (ECU) is coded for all-wheel drive (AWD)? If that's the case, there should be a '3' at the end of the coding, which indicates AWD. To switch to two-wheel drive (2WD), simply change the '3' to a '2' during the coding process."
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Translated on 08-07-2026, 8:41.
Back to top Profile PM Email
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Vibrations and Rumble Noises with 4Motion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8P Alarm: Gateway Issues & Error Solutions On-Board Diagnostics (OBD)
No new posts Passat 3C: Gateway Replacement Guide On-Board Diagnostics (OBD)
No new posts CAN Gateway A3 8PA: Incorrect Coding? On-Board Diagnostics (OBD)
No new posts VW New Beetle: Radio Gateway Replacement Dieselschrauber Bar
