LMM Heat Shield: Check Without Car.
Cord
Post01-02-2003, 0:25    Subject: LMM Heat Shield: Check Without Car. Quote
Hi there!
"I have a hot-wire mass flow sensor here, and I applied voltage to it and measured the output. When both protective caps are on, there's already 1.5 volts coming from the output. When I blew on the wire, the voltage increased to over 3 volts."
My question is: Is it normal for 1.5 volts to be output even in "standby mode"?
The LMM is a standard Bosch component without a CO potentiometer.
Translated on 10-08-2026, 17:49.
diesel.gustav
Post04-02-2003, 21:38    Subject: Best German Translation Services - Get a Quote! Quote
Deleted upon request.
Translated on 10-08-2026, 17:50.
Cord
Post04-02-2003, 23:51    Subject: Answer: Not a precise question, but here's an attempt Quote
Sure, you're welcome.
I thought LMM could also stand for "air mass meter."
Actually, the engine in that car is from a Volkswagen Golf VR6.
If it's supposedly normal for it to produce 1.5V even when idling, then it's not useful for me either.
diesel.gustav wrote:
Hello Cord,
You're talking about a Bosch hot-wire MAF sensor. To be precise, there's no such thing as a "hot-wire MAF sensor." A hot wire isn't used in a Mass Air Flow (MAF) sensor, which is also known as a throttle air flow meter. But maybe that's just being pedantic.
If you have a genuine hot-wire air mass sensor (HFM), then it's from a gasoline engine. It wasn't used in diesel engines.
Generally, a Bosch mass airflow sensor (MAF) or hot-wire air flow meter (HFM) outputs a voltage even when no air is flowing. The specific value depends on the sensor and its configuration. When you blow into it, the signal voltage typically increases, as you correctly observed.
If you have an HFM5 with reverse flow detection and you blow air in the opposite direction of the intended flow, the signal voltage will decrease; when blowing in the correct flow direction, it will increase. HFMs are currently state-of-the-art technology for diesel engines.
A very basic functional test via the signal voltage is possible for each of the sensors mentioned above.
Translated on 10-08-2026, 17:52.
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Vacation Checklist: Essential Vehicle Prep General Tips
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM MSG: Safe Check & Repair Without Car Access On-Board Diagnostics (OBD)
No new posts Install AHF in AFN Vehicle? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Lifting the vehicle Transmission, Chassis, Body & Interior
No new posts Lift Kit: Raise Your Vehicle's Height Transmission, Chassis, Body & Interior
